Kubota F-Series 72" Rear Discharge Deck Identification
   / Kubota F-Series 72" Rear Discharge Deck Identification #1
Esox
Massey Ferguson 390 4WD
I have a Kubota F3060 with the RC72-F30 side discharging 72" deck. I found a 72" rear discharge deck for sale, but I don't know if it will fit on my F3060 properly. I assume that I would need an RC72R-F30 for my F3060.
Strange that the left hand side wheel support arm is bent inward, but it almost looks like it may be that way on purpose. The seller knows nothing about it or what it came off of. Pictures are attached below. Any help or guidance would be greatly appreciated.
Thanks,
Esox
   / Kubota F-Series 72" Rear Discharge Deck Identification #2
Why are you wanting another deck ?
So I can have rear discharge and not blow grass into mulched areas or build up wind rows of grass clippings.
   / Kubota F-Series 72" Rear Discharge Deck Identification #4
Thanks,
Esox
Esox,
Welcome as a F mower user!
Could please you fill out your profile with some location info etc.
The model of the deck looks identical to my RC72R-F30 and the arm is bent on purpose in order to keep the left hand gauge wheel from traveling close to the edge like a situation shown below:
I replaced the worn out RD deck shell (shown below) on my F3060 few years ago with identical new deck shell.
Here's the mower when the new deck shell was first installed around 2017 or 18:
Here it is few years later:
As you can see above, I have also replaced the 90 degree gearbox with aftermarket one from eBay vendor around 2021 just to have a low cost spare.
It has worked out very well.
   / Kubota F-Series 72" Rear Discharge Deck Identification #5
My grass gets so thick I can’t run the side chute deflector on my SD Deck or it’ll windRow really Bad.
But I do get covered with grass & have to make 2 passes blowing it away from driveway & buildings.
I do miss that from my 72 RD Deck Zero that I sold.
I don’t miss cleaning radiator screen out every 2hrs & covering the under chassis with Damp grass tho.
Every application is unique.
Thanks for the replies. It seems that this deck should fit my F3060, but it will probably require some fixing. Its hard to tell from the pictures, but the covers seem to be needing some repair and that left wheel arm appears to be bent much further inward than it should be.
I'll post more after I see it in person.
   / Kubota F-Series 72" Rear Discharge Deck Identification #7
The left arm on my deck has been repair welded by the previous owner's shop so the angle could be off substantially?
It was previously owned by municipality and had all kinds of different hired help driving it!
   / Kubota F-Series 72" Rear Discharge Deck Identification #8
I am pretty sure my deck is unaltered. The RH side caster arm is parallel with the edge of the mower. The LH side is skewed. See attached pictures.
Someone hit something very solid to bend the arm that much. They are pretty stout pieces of steel.
Doug
   / Kubota F-Series 72" Rear Discharge Deck Identification #9
Doug
Doug,
Your deck looks original and good!
Mine must have been previously hit pretty hard in the left gauge wheel arm and that apparently was the weak link.
The arm was originally bent on purpose by design but was repair welded due to damage.
The arm repair is solid but looks so-so, however my plan is to replace both side arms when I switch to 15" gauge wheels sometime this winter.
   / Kubota F-Series 72" Rear Discharge Deck Identification #10
I do know a 72" rear discharge or side discharge deck is around 5 grand at the dealer. Myself, I like the side discharge better but that is personal preference only.
   / Kubota F-Series 72" Rear Discharge Deck Identification #11
One thing I did to minimize windrowing in heavy grass is, I drilled a hole in the side shield and I run with it up and held with a shock cord. That way the side discharge mower throws the clippings far enough not to windrow. In fact at rated RPM, I can throw them about 15 feet.
   / Kubota F-Series 72" Rear Discharge Deck Identification #12
Everything on the mowers is stout except the fenders. Probably why they cost so much new.
   / Kubota F-Series 72" Rear Discharge Deck Identification #13
I remove side chutes first thing on every mower.
   / Kubota F-Series 72" Rear Discharge Deck Identification #14
Arto,
I look forward to seeing the results of this project.
Doug
   / Kubota F-Series 72" Rear Discharge Deck Identification #15
I don't simply because when mowing near the roadside, I don't want to have anything solid impact a passing vehicle or tractor and we live on a dirt / gravel road and stones always wind up in the grass.
I just hook them up with a tarp strap and when mowing near the road, drop it down.
Guy down the road was mowing his side yard with the deflector removed and took out his wife's windshield with an errant rock. She was not happy and he had to pay for a new windshield.
   / Kubota F-Series 72" Rear Discharge Deck Identification #16
I could see that but I mow @ 3.5” missing most stones plus I don’t dare blow grass in road or driveway
   / Kubota F-Series 72" Rear Discharge Deck Identification #17
Unfortunately I have to mow along the roadside. Interestingly, near the next town to the west, there was a guy mowing with deflector up on the edge of a paved road and hit a car with something and there was a State cop right behind that car and he got hit as well and not only gave the mower guy a ticket but had is mower towed and impounded. Don't know all the details however. I could see a mower hanging from a wrecker going down the road....lol
   / Kubota F-Series 72" Rear Discharge Deck Identification #18
@5030 what height are you mowing at ?
   / Kubota F-Series 72" Rear Discharge Deck Identification #20
I just checked where my deck is set- 3.5". Seems like most of us run it about there.
Doug
2019 CATERPILLAR 950M WHEEL LOADER (A60429)
2019 CATERPILLAR...
2020 DRAGON ESP...
PENDING SELLER CONFIRMATIONS (A59904)
PENDING SELLER...
2015 Peterbilt 579 T/A Wet Kit Day Cab Truck Tractor (A59230)
2015 Peterbilt 579...
2012 KINZE FLAT FOLD ROW MARKERS SET FOR 12 ROW 36/38 STACK FOLD TOOL BAR (A55315)
2012 KINZE FLAT...
1454 (A57192)
1454 (A57192)
