2520 Snowplow size?
   / 2520 Snowplow size?
The snow blowing in my face was one of my reasons for liking a plow, and also the speed of the plow. I'd run it wide open in Low range most likely, and I highly doubt a blower would be able to handle that speed. :confused2:
I'm used to plowing with my 700cc ATV and a 60 inch plow, so this 2520 can only impress me from the ATV! :thumbsup:
I'm really liking the Truck plow versus the JD quick hitch and then a plow on that. I'd like something that could be removed easily tho, so the FEL could go back on.
The snow melting is not an issue. My tractor lives in my 36x60 2 story garage! :laughing: There is in floor heating that keeps the garage in the 50's and then the tractor gets parked over one of the 4 floor drains!
THANKS for all your input and ideas guys. This is what makes this board so great. Its everyones input, and opinions.
   / 2520 Snowplow size? #12
I made mine as a quick hitch, that stays with the plow, tilts onto the front mower draft plates and bolts (2 bolts) to the weight bracket. The time it takes to tighten two nuts on the bolts and connect the three hoses is about it. Probably a total of 10 minutes to get the plow off and the FEL mounted at most. :)
Search on Western plow for previous posts that include quick hitch pics.
   / 2520 Snowplow size? #13
Believe me, it is not fast compared to having that 5-6" snow and jumping on the tractor with plow and in medium (sometimes high) gear and making a wide path (wider than the snowblower) at more than a walking pace down and back. No snow blowing back in your face (unless you have a cab) and done and parked back in the shed. Also, a big point to me for a blade, is one quick drop and the excess snow falls off before parking. A snowblower takes a while to clean all the latent snow off or let it freeze or melt on the shed floor. Can't risk freezing on, or it won't work well the next time out.
I run R-4's and only on rare occasions do I need the chains. and you will need chains on for the snowblower at these times too. They are when the conditions are right for ice which is sometimes unavoidable (wet snow and temps drop, or when freezing rain leaves a layer on the drive). Most winters the chains don't get put on and the R-4's work just fine. Last winter we had the 15" snow that was very wet. It was work to move with the blade, but still worked better than the neighbor with a 54" snow blower (too wet for him to handle so I was asked to help him out with the blade - - after I put the chains on the R-4's :) ).
But it is a tough decision at the point you are now. Best of luck to you making it. And either way is fine with me.
Most people around here think the pecking order is front blower, rear blower, blade. You don't need chains with the front or rear blower but you do with the blade. Never had trouble with heavy snow and never used chains even with the big storms last year. What do you do when you don't have a place to push the snow but it keeps coming down, now you have to put the FEL back on to make room, how fast is that?
I've used a blade have you ever used a front blower? If you had the choice would you have a front blade that you pushed snow forward with or a rear blade that you pushed it back with? Looking over your shoulder for a mile while you plow is simply no fun in my view.
Rob
   / 2520 Snowplow size? #14
I have a 4115 which is simular to your 2520. When I bought my tractor it came with a 6 1/2 ft. Curtis power angle snow blade. This blade is heavy and attaches to the fel boom. I didn't have enough ballasts for it but the tractor handled the blade very well. This year in West Virginia we got 30 inches of snow that we generally don't get. It depends on how deep and how wet the snow is for any blade to perform I quess. My driveway is over 100ft long in asphalt and a little over that in millings and I did not need chains with my R4's. I like the ability to lift the snow when the piles get high also you can't beat the power angle. Some think this size blade is to big for that size tractor but like I said it handled it well. Hope this helps.
   / 2520 Snowplow size? #15
Rob
Guess I'm not "most people". :)
I'd beg to differ on not needing chains on my 12% section of drive with a blower, front or back. Ice is ice, and slippery is slippery. Simply will not run anything without chains. Flat may work without chains, but then wouldn't need them for the blade either. Chains are on my tractor maybe twice, or three times a winter.
And tho I have planned for a quick switch from the blade to the FEL if needed, I've never had a problem bucking the snow back when it gets deep. Just takes a bit longer seat time.
And as mentioned, have not removed the blade to attach the FEL in the 10 winters in WI, most of which have had some great snow falls.
And yes, I've used a blower on the front and it was nice, but slower than the blade. Maintaining the blower is more work than I want compared to very little to maintain on the blade.
Now to add to the pushing snow back, I've added a wing plow. Mostly because it was because I just wanted to see if my design would work. It does and is a joy to mow the snow back over the edge of the ditch to lessen the drifting that can take place on that north side (about an 1/8 of a mile of drive).
I can only say what I like better, and do not care if others prefer a snowblower. :D I am perfectly ok with that. But I'll stick with a blade for less original cost, less maintenance, faster snow removal, and that sums up as more fun for me. :D :D
Carry on.
I have the JD 47 inch front snow blower on my JD X475 (23 HP garden tractor). It works really well for blowing snow, but my 475 really could use a couple more HP for sure. It labored it pretty hard last year when we had 14 inches of medium weight snow. It was a slow job, but luckily I didn't have a huge area to clear off. If I would of had my ATV and snowplow, I would have been done twice as fast, but the snow would have been all piled up in banks, whereas the blower packs the snow and it hardly takes up any space after its blown away.
If my banks get too built up, I can have my buddy come push them back with his Chevy with 502 Cubic Inch (8.1L) motor! :thumbsup: He plows for me now, and its awesome seeing that beast play with his plow.
   / 2520 Snowplow size? #17
Fairve. Not sure on the spelling.
Will your blower fit the 2520? No doubt it's slower than a blade. Blades are great, I've got two. The benefit I see is with a blower is drifting. On my 500' drive I had about 75' across an open field that drifted every day. I ran out of places to put it with a blade. With a blower it was always moved out of my way the first time.
We've had some big snows these last couple years. I know moving a 10" snow with a blower is slow, but for me, it's slow with a plow too.
With your setup I'd be in good shape. The 2520 would be the everyday plow, and for the big snow I'd have to break out the smaller 475.
   / 2520 Snowplow size? #18
Carry on.
Not disputing you BT, to each his own and I appreciate your views, also we all have different plowing conditions. Up here we get some big storms, sometimes for a week in a row (we're in a snow shed area) at it gets to the point where there is simply no place to put the snow if you're pushing it. The other problem is we often get a January thaw and with a gravel driveway you're start pushing driveway off of your driveway with a blade!
Rob
   / 2520 Snowplow size? #19
If the drive thaws out, the blade can be set up with skid shoes to not touch the gravel just the same and as easy as a snowblower. IMO. As well, also will work to carry them. :)
So if i were to try a snow plow. How wide should I be looking for? Like 6 foot, or 6.5ft? I don't want to put a plow on it thats impossible to make the very first pass, but I also don't want a narrow one that makes the small snowfalls take forever to clean up.
1992 Ford L9000 Cab Chassis with Low Mileage Cummins (A56436)
1992 Ford L9000...
Ratchet Straps (A59230)
Ratchet Straps...
IRET13 ELECTRIC TRICYCLE (A58214)
IRET13 ELECTRIC...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2009 Peterbilt 335 Cab and Chassis Truck (A55852)
2009 Peterbilt 335...
1969 VOLKSWAGEN BUG (A59575)
1969 VOLKSWAGEN...
