Adding a subplate to a 12v power pack?
   / Adding a subplate to a 12v power pack? #1
davedj1
Jackson, NY
Kubota L2501
   / Adding a subplate to a 12v power pack? #2
Dave
Are there any additional pressure or tank port connections on your unit? My concern is that with the lift, check, dump incorporated into that casting you will not have an option for adding functions via a sub plate.
   / Adding a subplate to a 12v power pack? #3
Unless someone has experience with that particular unit, only the manufacturer/dealer could probably tell you what you can and can't do with it.
   / Adding a subplate to a 12v power pack? #5
It's not uncommon for items to be sold at price point and not be able to be upgraded.
   / Adding a subplate to a 12v power pack? #6
any vehicle junk yards in your area? would a power pack from a wheel chair lift work?
Land Pride FDR1660 (A53317)
Land Pride FDR1660...
2012 Ford E-350 Enclosed Service Van (A59230)
2012 Ford E-350...
12FT X 20FT LIVESTOCK METAL SHED (A58214)
12FT X 20FT...
2003 CASE 590 SUPER M BACKHOE (A60429)
2003 CASE 590...
Dual Tailwheel Rhino 284 7ft Cutter 2.5in cut capacity (A56438)
Dual Tailwheel...
405 (A52706)
405 (A52706)
