Adding a subplate to a 12v power pack?
   / Adding a subplate to a 12v power pack? #1
davedj1
Jackson, NY
Kubota L2501
   / Adding a subplate to a 12v power pack? #2
Dave
Are there any additional pressure or tank port connections on your unit? My concern is that with the lift, check, dump incorporated into that casting you will not have an option for adding functions via a sub plate.
   / Adding a subplate to a 12v power pack? #3
Unless someone has experience with that particular unit, only the manufacturer/dealer could probably tell you what you can and can't do with it.
   / Adding a subplate to a 12v power pack? #5
It's not uncommon for items to be sold at price point and not be able to be upgraded.
   / Adding a subplate to a 12v power pack? #6
any vehicle junk yards in your area? would a power pack from a wheel chair lift work?
TANK MANIFOLD (A58216)
Forward 10,000lb Two-Post Electric Auto Lift (A55851)
Forward 10,000lb...
Tanker Trailer (A59230)
Tanker Trailer...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A59231)
2009 Skeeter SL190...
1995 NEWTON CROUCH PULL SPREADER (A57192)
1995 NEWTON CROUCH...
2019 BOBCAT T870 SKID STEER (A60429)
2019 BOBCAT T870...
