Adding a subplate to a 12v power pack?
   / Adding a subplate to a 12v power pack? #1
davedj1
Jackson, NY
Kubota L2501
   / Adding a subplate to a 12v power pack? #2
Dave
Are there any additional pressure or tank port connections on your unit? My concern is that with the lift, check, dump incorporated into that casting you will not have an option for adding functions via a sub plate.
   / Adding a subplate to a 12v power pack? #3
Unless someone has experience with that particular unit, only the manufacturer/dealer could probably tell you what you can and can't do with it.
   / Adding a subplate to a 12v power pack? #5
It's not uncommon for items to be sold at price point and not be able to be upgraded.
   / Adding a subplate to a 12v power pack? #6
any vehicle junk yards in your area? would a power pack from a wheel chair lift work?
2012 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
294 (A52706)
294 (A52706)
LAND PRIDE RCR1260 5' ROTARY MOWER (A59823)
LAND PRIDE RCR1260...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
Bush Hog 72in Rotary Brush Cutter Tractor Attachment (A55852)
Bush Hog 72in...
2019 CAT 259D (A60462)
