any toro groundsmaster fans on here?
   / any toro groundsmaster fans on here? #431
tHANK YOU MUCH - aGAIN. Dang Caps Lock always gets my fat fingers.
I would urge everybody to check their rear axle bushings and the deck arm bushings.
From what I read, they should be checked every 500 hours. If you let them go until the pins and important parts are wore. It's a much more time consuming fix than just swapping the brass bushings.
   / any toro groundsmaster fans on here? #432
1otP0
   / any toro groundsmaster fans on here? #434
Just saw this thread...
I'm traveling 85 miles tomorrow to look at a 325D...
I hope to bring it home...
Here are the pics...
Owner states 455 hours and A+++ shape...
Any input would be appreciated...
Did you end up buying this one? I noticed it was still listed.
   / any toro groundsmaster fans on here? #435
I was negligent in greasing the bearings on the back wheels of the 233D.
The bearings spun just enough for there to be perceptible wear in one spot on the spindle - inside bearing - right side.
What are my options? Or should I just throw it together and go?
On 10 acres, those little wheels go round and round - a lot
I peened each spot with a center punch in 4 places. Tightened the bearing right up. It still slides on and off easy enough.
I actually had to file my peen marks a tiny bit
   / any toro groundsmaster fans on here? #436
Sounds like a good fix to me. :thumbsup:
   / any toro groundsmaster fans on here? #437
Yes...
I've used it now for several months...
Need to get a fuel sending unit and a new hour meter...
Purchased some spacers to raise the deck and a couple of used weights...
Had to get a cap for the deck adjustment that sits on top of the spindle...
Darn thing has the spring and spacer built in that uses a circle clip...
Eventually just sit the spring in it without the circle clip...
May just put a pin through the next one...
It is a great mowing machine...
No trimming involved with the 6 foot deck...
It's offset to the right about a foot or so...
My yard has never looked better...
They have a great deck and the Mitsubishi diesel is a fuel miser...
   / any toro groundsmaster fans on here? #438
Yes sir! Just saw your post for the first time and instantly became a member
   / any toro groundsmaster fans on here? #439
:welcome: to TractorByNet! :thumbsup:
Post some pictures please.
2017 Ford F-150 Pickup Truck (A54814)
2017 Ford F-150...
2014 VOLVO VNL DAYCAB (A58214)
2014 VOLVO VNL...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A58018)
2020 INTERNATIONAL...
2019 fORD f550 (A55973)
2019 fORD f550...
2006 International Bucket Truck (A55973)
2006 International...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
