Anyone Using a Puma 80" or 84" Snow Blower?
   / Anyone Using a Puma 80" or 84" Snow Blower? #1
Hilbilly
Barriere, BC
Kubota Grand L6060HSTCC
Looking for anyone with experience with these blowers and what size tractor you are using it on.
   / Anyone Using a Puma 80" or 84" Snow Blower? #2
All I can tell you is... Your 6060 don't have the balls to run an 84" blower, single or 2 stage.. 60 maybe, 72 at the most in light powder only. I have a Lucknow 84 I run with a Kubota M9000 and it is all the tractor can handle and sometimes too much for it. With 84 pto horsepower. Blowers are wicked power eaters. You'll be much happier with a front blade versus a blower. I have them both and I use the blade 95% of the time.
   / Anyone Using a Puma 80" or 84" Snow Blower? #3
Amen!!
   / Anyone Using a Puma 80" or 84" Snow Blower? #4
I call a bit of BS... My 25hp PTO L3200 ran a 60" just fine in packed Colorado drifts. A L6060 with double the HP & probably HST can easily do a 72", probably in the 80" range if you're fine going slow. HST means you can dynamically adjust your speed vs load. I agree plowing is faster 90% of the time, but there are lots of cases ot doesn't cut the mustard.
Does going beyond 72" buy you much? 2 passes with a 60 was plenty for my driveway. Wider wouldnt have opened any more useful area. My parking area might have been able to drop from 6 100' passes to only 5 with a wider blower. Not a huge win.
Looking for a 72" blower now to match my 72" wide L4060HSTC. The 60 got sold as it was to skinny for my new machine.
   / Anyone Using a Puma 80" or 84" Snow Blower? #5
Have an 84 inch, 20 inch fan, blower on my Massey 1742. Works for everything I need to clean up. Hst makes a big difference in operational capabilities. Previous land owner had an 84 inch Allied blower on a Massey 1105. That blower was also a foot higher in the body and had a much larger fan, used all the power the tractor had. Need ro match the blower to the tractor.
   / Anyone Using a Puma 80" or 84" Snow Blower? #6
Not sure I agree with this. I have a buddy with an LS XR4155 easily blowing through 2ft of snow with a 96" blower. Another buddy with an 84" on a 35HP Kubota and loves it. Around here I see many 60" to 84" blowers hanging off the back off 30 to 60hp machines. We get lots of snow here in Maine, wet, dry, you name it. I am about to get a Woods 74 inch for my 36HP machine and the dealer says it will run it easily.
   / Anyone Using a Puma 80" or 84" Snow Blower? #7
X2
I have a 78" Lorenz and 32 hp at the PTO. Sure, I can bog it down if I ram into a plowback, but with the HST, creeping into the plowback is not a problem. Tractor Data says your tractor is 67" wide; 72" blower would be the bare minimum I would mount.
   / Anyone Using a Puma 80" or 84" Snow Blower? #8
X2
I measured my rear tires and they are about 70 or 71" outside to outside. I'm thinking 74" will be just wider than my rear tires so it should work.
   / Anyone Using a Puma 80" or 84" Snow Blower? #9
I won't tell my L6060 you said she has no balls:D. My 79" snowblower is coming any day now. This tractor had better perform well or I will be extremely bummed out. Not sure how the HST makes things better for snow blowing but glad I have it.
   / Anyone Using a Puma 80" or 84" Snow Blower? #10
My old B2150 only had 18 HP at the PTO and had no trouble at all running my 60" blower thru a 30" snowfall.
JOHN DEERE 7300 LOT NUMBER 18 (A53084)
JOHN DEERE 7300...
2005 Honda Accord LX Sedan (A55853)
2005 Honda Accord...
Golf Cart (A55853)
Golf Cart (A55853)
New Powersmart 4400 Watt Portable Generator (A54865)
New Powersmart...
2008 Chevrolet Uplander LS Van (A55853)
2008 Chevrolet...
2842 (A54756)
2842 (A54756)
