At Home In The Woods
   / At Home In The Woods #1,751
Obed, regarding keeping the bricks clean I've seen some guys put bales of straw up against the brickwork to keep mud from splashing up against the bricks. If you just put dirt against the brick with heavy rains it could splash up and "dirty" the bricks. Just a thought! The brick layers did a terrific job! You've got to be very pleased with their work.
   / At Home In The Woods #1,752
Obed,
the middle pic in your last post gives a good over all view of the area that you plan to have vinal siding. My opinion is that a kickout flashing will be plenty to take care of your issue. I say this due to two things, first the roof overhang is such that not much water will see the kickout, and second it is a small area that will have vinal siding. OK maybe three things the valley above will direct most of the water coming off the roof away from that area as well.
   / At Home In The Woods #1,753
One thing I have learned is your tractor has been a necessary tool. I have had tractors for a long time but reading this thread from day one I see many of the same chores you use yours for I do also. You forget how handy they are until you see someone else breaking their back.
Chris
We had lots of conversations with the framer and the vinyl guy regarding the back porch. We originally wanted the triangular area (see yellow arrow) at the ends of the porch above the beam and below the roof to be screened in. However, it was getting tricky to do that and make the beam and vinyl soffits look good. We also had a dilemna regarding how to transition from the eyebrow to the porch. Inthe end, we decided that we will fill in that triangular area with siding on both ends of the porch.
The bottom of the beam is 9 ft above the floor. The framer was going to make the beam 8 ft until we talked to him. The extra foot makes quite a difference regarding the view of the woods. The ceiling will be "cathedral". I'm not sure if that's the correct term since it has a shed roof instead of a gable. The porch will be screened in. The screens will be removable; we plan to remove them during the cooler months when bugs will be less likely.
The wife took me out to the porch and said, "This is really going to be nice." With all the stress she's under coordinating the building process, it was good for to her momentarilly see, however brief, that she might actually enjoy the house. With everything going on, with all the problems we have to address and solve, we have difficulty seeing the end result.
On the other hand, last night I did more footer cleaning and backfilling around the basement. The weather was wonderful; things have cooled down some. I enjoyed the work with the pleasant weather and the hope that we might soon be in the house. My wife isn't there yet; she is working everyday coordinating with subcontractors, suppliers, and doing research. I'm looking forward to when my wife will be able to step back and see the light at the end of the tunnel.
The wife picked up some straw to protect the brick.
Chris
Chris,
Yes, the tractor has been indispensable. When I first got the tractor, the backhoe seemed mostly just a toy. I found that I didn't use it very much. But when we started building the house, that changed. The BH has been a valuable tool. During the house build, I've gotten fairly proficient with the backhoe. I can now pretty much move the bucket however I want it to go. I couldn't say that before we started building the house.
If I didn't have the tractor, I'd have to pay someone to do all this work and it wouldn't be done the way I'd do it. For the cost of the tractor, could I pay for all the work to be done? Yes. But then I wouldn't have a tractor.
At my last house, we owned 8 acres in the country. I didn't have a tractor. As a result, things like badly needed bush hogging got neglected cause I hated to pay $300 - $500/day to rent the equipment. I don't have any excuses now.
Obed
Screened Porch Flooring Question
The composite flooring manufacturer instructions indicate to leave 3/16" to 1/4" gaps between the boards to allow for expansion. Will mosquitoes come through these gaps? If so, it seems that screeing in the the porch would be useless. Please help.
Thanks,
Obed
I wouldn't want any place like that up here in the frozen north . I think it would eventually leak. Here most would build the wall out flush with the brick and flash and side as normal. Looking good Obed
That's a great idea. Wish we would have thought of that earlier. At this stage in the game, it looks like we will go with the kickout flashing.
Obed
   / At Home In The Woods #1,759
The composite flooring manufacturer instructions indicate to leave 3/8" to 1/4" gaps between the boards to allow for expansion. Will mosquitoes come through these gaps? If so, it seems that screeing in the the porch would be useless. Please help.
Thanks,
Obed
You could you staple screening material on the top floor joists before you put your flooring down. This would keep the bugs out and allow the spacing that you need.
Rick
Rick
Rick, that's not a bad idea.
Has anyone out there built a screened porch with the flooring boards spaced 3/16" or more apart? Have biting insects become a problem?
Obed
2019 John Deer 3038E 4 x 4 Tractor w/300 E Loader, S/N 1LV3038EJKK126097, Diesel Engine, Joystick (A59076)
2019 John Deer...
12 ft Shipping Container (A55973)
12 ft Shipping...
202476 (A54757)
202476 (A54757)
72in Forklift Safety Basket (A56857)
72in Forklift...
2017 Ford F-550 Crew Cab Enclosed Service Truck w/ Liftgate (A56858)
2017 Ford F-550...
35176 (A55758)
35176 (A55758)
