B2320 Back wheel started to fall off @ 22 hr's
   / B2320 Back wheel started to fall off @ 22 hr's #41
Monster5601 said:
The manual I got with my B3030 includes a torque spec sheet by bolt size. Additionally, it lists the torque requirements for the wheels as:
Torgue Specification Torque
Front Wheels 57 to 67 ft-lbs
Rear Wheels Nut 123 to 141 ft-lbs
Rear Wheels Bolt 146 to 166 ft-lbs
Thanks! Off to get a bigger torque wrench...
   / B2320 Back wheel started to fall off @ 22 hr's #42
Interesting thread. Glad Kubota stepped up on a new rim for the OP. I did check my lug nuts during the 50 hr service last month but couldn't get my torque wrench onto the nuts on my BX since the tire sidewall was in the way. Dumb question. If I pick up a 1/2" drive extension so I can reach the nuts, does using the drive extension throw off the torque wrench setting? Been debating this in my mind but not sure. Opinions?
   / B2320 Back wheel started to fall off @ 22 hr's #43
Not as long as the force is applied along the same axis and not off to the side which is easier to do the longer the extension is.
As long as you are going to keep an eye on them then the locktight is not really needed.
If something is regularly working loose, that's a red flag to use locktite rather than baby sit it.
   / B2320 Back wheel started to fall off @ 22 hr's #45
Are you sure the one bolt is on backwards. Tractor wheels have some the bolts in the pattern backwards to make it easy to get a wheel on, and are designed that way. Not sure if this is the case with yours but I would check.
HS
   / B2320 Back wheel started to fall off @ 22 hr's #46
Just FYI for those who do not know. The reason lug nuts can come loose (and the reason you check them at low hours) once, and then never again is the paint on the wheel. Believe it or not, the paint will compress and/or flake under the nut after a few hours. Sometimes, it is not enought to notice, other times, the lug nut gets looks and works its was off. I know alot of customers who think that a dealer did not tighten them during assembly because the are loose at 10-30 hours. I am sure this is true some times, but often, it is just the paint. The same think can happen with loader frames, so be sure to check your bolts on the loader frame for the first few (50) hours. I have read several differant suggestions on hours (5, 10, 20, 25, etc), but I would just check them several times in the first 50. Also, you do not really need a torque wrench (use on if you have one), us can just make sure they are tight if you don't have access to the tools. Just FYI for anyone interested.
   / B2320 Back wheel started to fall off @ 22 hr's #47
There was a retired guy that had quite a little business painting wheels on the side... he built a machine that would slowly rotate up to 6 wheels to get a perfect finish... he always put dummy plugs in the bolt holes because of too many problems when painted surfaces are torqued.
Update.
STILL waiting for my wheel. Dealer seemed to have lost the one that was ordered. Dealer blames Trucking company/Kubota.
Meanwhile I did check other wheels. I could barely budge any. Only one loose is the one that had at least one lug on backwards and almost fell off.
I managed to get all the old studs out. I had a heck of time getting them out.
Keep in mind the studs were worn only near the base.
A stud and nut that had no visible damage I would screw on a nut and it would start to get tight after say 3 turns or so and then eventually the stud would start turning inward. Then I try to remove the nut and it was so bound up the stud would come out (with quite a bit of force). But at least the stud came out. This happened like on 3 studs with different nuts. Screw nut on, it would jam so bad that when I back it out stud would come out.
One stud fell out, one was hand tight the whole way. And the other was the backwards lug and it came out easy nut and stud as one.
I swear some might have had locktite and others not.
The studs are not hardened steel like cars. They are quite soft.
All the holes for the studs look clean. But I'm worried the new studs might bind like the nuts did while trying to remove studs.
So I'm thinking of running a tap through them in case there is some locktite or burr. But I'm also worried I may not "catch" the original thread with the tap (I've done that before). It's really tricky catching an old thread with a tap. Or that I may tap them out slightly bigger than factory and may cause more trouble.
Any suggestions appreciated.
I wish the hub held the wheel centered like it does in the front so it was not so critical the studs are perfect.
   / B2320 Back wheel started to fall off @ 22 hr's #49
After reading your post I checked the wheels on my b2920 ,they were loose! way too loose somewere around 25 foot pounds of torque I retorque them and i'm going to recheck them again, I only have 4 hours on mine
   / B2320 Back wheel started to fall off @ 22 hr's #50
taos, good catch. Gotta say, however, that in 4 hours, it seems almost impossible that the dealer torqued them correctly when he installed the wheels when they took that tractor out of the crate. Golly. :eek:
2012 Kenworth T800 Heavy Haul Truck, VIN # 1XKDD40X6CR301872 (A57453)
2012 Kenworth T800...
LOT: (2) Shelving Units w/Equipment Parts & Hardware (TANKS NOT INCLUDED) (A59076)
LOT: (2) Shelving...
Toro ProCore 648 Walk-Behind Turf Aerator (A56857)
Toro ProCore 648...
TANK MANIFOLD (A55745)
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58216)
RAKE ATTACHMENT...
2024 8x22 Enclosed Trailer (A57453)
2024 8x22 Enclosed...
