Comparison B26 vs B series tlb
   / B26 vs B series tlb #1
Rhino421
Milwaukee, WI
B26 TLB
Hi, I was hoping some B26 and B2630 or other B owners could give me a little insight. I found a used B26 less than 100 hrs (rental) and the price doesn't seem bad (just over 20k). It has the aux backhoe hydraulics but no thumb. I know it is a commercial version and the front loader doesn't come off. I am trying to do alot of landscaping on 2 acres and know this would work well for that. I will not be using it to mow the 2 acres. I also have interest in hunting land (60 acres) that we cut trails through for bow hunting. I would like to start some small food plots. I am wondering if the B26 with 19.5 hp pto and 3000+ lbs without backhoe would do a fair job in this regard. I know I could find a used b series tlb cheaper and wonder if the B26 is worth a higher premium. I do like the added backhoe length and power. I do have to trailer it 200 miles 1 way and the hunting land is only a small portion of what I need the tlb for. I have looked at the L3800 bigger( size,weight, power) but can't get past the jerky 3 pt(if I do find an unjerky 1 that may change things:thumbsup:) and have alot of grading in my future. The 3540 is bigger yet but weight and size around the 2 acres becomes an issue. I know about the clan that states rent a backhoe but I have thought alot on that subject and will be getting one with whatever tractor I end up with:D Any insight would be welcomed... PS like the additional features/cost of used but not opposed to new with 0%..... FYI, B26 out of touch new:(
   / B26 vs B series tlb #2
The maneuverability of the B26 coupled with its strength and toughness makes it hard to beat. If you have the extra money I think it is worth it. I have a B21 and the size and turning radius is a big plus around my place which is covered with gardens, paths and skinny roadways. I use it to cut pads and terrace down the slope of my 10 acres, plus I grade/maintain two miles of gravel road using both a King Cutter BB and a Landpride grader blade. Along with the tooth bar on the bucket, not much stops it.
   / B26 vs B series tlb #3
A little over 20K for a B26 with less than 100 hrs is an excellent price. You can always get a thumb later since the most expensive part of option (aux hyd.) is already on the BH. Just be thorough so the 100hrs was not an abusive 100 hrs. I have a B3300tlb and am pretty happy with it.
Is the 3pt hitch included? The only thing you are giving up with the B26 is a little pto hp, but you should be fine for uses you outlined. I am sure the beefier construction will be to your advantage.
I don稚 think you will find an equivalent used b tlb with same hours for much less if at all.
   / B26 vs B series tlb #4
Just an observation and not a response to your question, but I find it odd that a rental outfit would be selling a B26 with only 100 hours, or did you mean 1,000 hours? At 100 hrs it would be barely broken in.
   / B26 vs B series tlb #5
Wow, just over $20k? There's a dealer near me that has a couple of them with the almost 300hr one having an asking price of $29k. Would hate to know what they want for the 125hr one! Granted, they both have the hydraulic thumb and round back bucket with bolt on cutting edge though, so not truly comparable to the one you're looking at. Both are rental returns. About a year ago, there was a private party one with the hydraulic thumb going for around $23-24k.
   / B26 vs B series tlb #6
I wanted the B26, I ended up with a L3700 instead.... With I had the 26. For just over 20k.... Why are you not down there stroking a check? that is way cheap.
   / B26 vs B series tlb #7
That is a good price. I just bought a B26 last fall with 150 hrs for 25. I was also thinking about a bigger machine but I am glad I stayed with the B series. Very handy in the woods. I bought a grapple bucket for it and have gotten a lot of work done. You do have to be careful and understand the machine is small and can tip real easy. Loaded it is way worse. Keep the load low.
I replaced a B20 with the B25 and the backhoe is way stronger.
   / B26 vs B series tlb #8
The B26 is a lot of machine for its size. I bought one last year and love it. If the loader was removable it would be the perfect machine. Mine came to $35,000 out the door. That included the hydraulic thumb, QA bucket, 5 yr Kubota insurance, work lights and tax. That was a great deal for my area. Every other dealer wanted 40+. $20 grand is a steal with only 100 hrs. Good luck
A further update. The price turns out to be $23k subject to negotiation:D.. It is at a rental yard but the person I need to speak with isn't in til tomorrow:(. I was told it is a 2008 with only 87hrs... It has been sitting outside so some fading and a little rust but overall excellent condition per sales manager. Detailed pictures coming tomorrow (100 miles away).. He didn't have alot of info but did state no thumb or 3 point arms. The pictures I did see show it has the roundback bucket with bolt on edge and aux hydraulics on the hoe. It also has the stabilizer pads. The sales rep stated that they had bought it thinking it would rent more but didn't. Stated the loader isn't the strongest and neither is the backhoe( gotta love the sales pitch):thumbsup:. He stated people would either rent a skid steer or excavator so the B26 must go... If things go well I will be driving to see it tomorrow..
   / B26 vs B series tlb #10
I bought one in 2007 new and the 3 pt. arms were standard.Also,I dont understand about the loader or the hoe not being the "strongest".
These machines are not a full size Case or Deere backhoe,but i believe they will hold their own with any of comparible size.I'm happy with mine.
Also,I dont know if i'd go for that story about not renting it much.It seems to me they could keep it a couple years and deduct it somehow on taxes as a loss,but maybe they've already done that to the limit.Just make sure before buying you check it out real good.I know rental places around here usually keep things till they are dead or well on the way.
Just saying watch so you dont get burnt.
digger2
   / B26 vs B series tlb #11
I got it............rent it for a few days with the option of your few days rent goes towards the purchase if you decide to buy.Do that and really put it through its paces to see if it works OK. Beleive me,if it works OK
(and it should with that low of hours)it should handle anything the average guy can throw at it.Mine does.
If they dont agree to this.......BACK OFF IN A HURRY.
Still waiting on further info and pictures. Don't need to drive 2 1/2hrs to have the guy I need to speak with not around or to see it is more weathered than explained. I do have a question regarding size of implements. I know it is a 19.5hp pto and would like to know what size brushhog you guys are running behind them. I know the 5pto per foot but is that too small behind the B26? Do any of you run 5 footers with good results? I ask because of the hunting land we cut trails through. It does become tall grass and we do have 1-2 in saplings and brush. What size box blade (5 foot) could you get by with a 6 foot or is that way too big? (Have 1 available to borrow). Tiller size? Needed for food plots. Anybody pulling a plow and if so what size seems to work. I can read and look all I want but nothing beats first hand experience:thumbsup:
Digger I do like that idea but with a 2 1/2hr drive I may wait to see it in person and if any red flags pop up during my inspection I will use that approach.:D On that note anything in particular I should be on the lookout for on the B26 inspection?
   / B26 vs B series tlb #14
As part of the deal, see if they will service the tractor. Change all filters, fluids, etc. Fill the rear tires for you and provide any missing 3 pt. arms, buckles, etc. If there is some fading, have them throw in a quart of Bright Orange II and the Blue/Gray paint for the frame/bucket. If decals are scratched, missing, they can also throw in a set of those.
Oh, and don't forget to ask for a free Kubota baseball cap.
   / B26 vs B series tlb #15
I bought a B26 with 313 hours on it almost three years ago and I haven't regretted my decision one bit. I'm in Canada so I can't really give you a price comparison.
The 3 PT bits and bobs are stored on either side of the frame just below the driver's compartment. Unless you know what to look for, they really don't jump out at you. My B26 was also a rental and the 3 PT parts had never been used, nor had the BH ever been taken off. I took the 3 PT pieces off, cleaned and lubricated them and now store them in the summer (I only use them for my rear mounted snowblower) rather than putting them back on the tractor to be exposed to dirt and water all summer.
If you do go ahead and buy the tractor I suggest you take the BH off, lubricate the mounting pins and then re-install the BH. The BH comes off in about 5 minutes and only takes a bit longer to re-install. As I said, mine hadn't come off, and at 313 hours was a bit..ch :mad: to get off. I had to pound on one of the mounting pins till it finally came loose. Well lubricated every year (they don't have any grease nipples) they should slide on and off like a charm.
   / B26 vs B series tlb #16
Just a word of caution. If the tractor does not have the 3pt hitch parts they will run close to $1k from Kubota. As the owner of a B21 and a L39 you can tell I would have nothing but good to say about the Kubota TLB's.
MarkV
   / B26 vs B series tlb #17
A 54" bush hog will cover the tire tracks and is about as much as I'd want with 19 PTO hp. Woods makes one in this size, might be other companies as well. A 5 foot bush hog is far more common, and I have seen some on B26's, but I think that would be pushing it for any type of heavy cutting.
5' box blade would be about ideal, that's what I use on my B3200 and it handles it well. 6' is too big for anything but very light work.
Good luck on your purchase. I don't have a B26, but I've spent many hours running them for my business. Great little machines.
   / B26 vs B series tlb #18
Maybe he should ask for a 10 year warrantee too. The man is getting a B26 with 87 hrs, for less then $23,000. He should take it and run. Actually one of the other posters had the best idea, rent it for a few days, and if you are happy with it and decide to buy it, have them take the rental fee off the purchase price. You can't ask for more then that, especially at that price.
As far as the rear mower, I can't help you with that, never had one. The machine itself with the BH is a little pit bull, and you won't regret buying it. You can't compare it to the other B class tractors. The B26 is in a class of its own, that's why the rental yards buy them. Tough little machine. Keep us posted and good luck.
   / B26 vs B series tlb #19
MarkV
I paid $500 for mine from Messicks, not sure if I spelled that right. I will check and get back to you. It was not an after market part either.
   / B26 vs B series tlb #20
Yup Messicks, that's the place, can't beat their prices
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
1979 Ford H-48 Excavator (A56438)
1979 Ford H-48...
2022 Bobcat T66 (A53317)
2022 Bobcat T66...
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
84" HYD CURVED LOG GRAPPLE (A52706)
84" HYD CURVED LOG...
