B3200 Vibration Update
   / B3200 Vibration Update #111
The timing was off 8 degrees on my new 3200. Correcting this reduced the vibration. Not eliminated it but its now at a level that is not, in any way, an issue. The biggest change was the way it starts. No missing, sputtering and belching white smoke on start up. Even when its 10 degrees outside. Glow it for 5 seconds or so and it snaps to life instantly. Well worth looking at if you have a 3200 that acts like it has a "cold cylinder." No more missing until warmed up. Now I'm a happy camper.
Was it 8 degrees early or late?
   / B3200 Vibration Update #112
2. compression, the piston rises and compresses the diesel fuel and air until the metered fuel is compressed to the point it explodes and consumes the that was pushed or pulled into the air intake via the valve train. .
think about this. If this was true then injection timing would not be critical and there would be no way to control at what angle of the piston the explosion would take place. If this method even worked, I imagine it would be a real noisy engine.
Some newer electronic controlled engines with multiple injetions spread the fuel over the power stroke to reduce the impact of the first explosion and thus reduce noise and vibration.
   / B3200 Vibration Update #113
Not sure if was late or early on the timing.
   / B3200 Vibration Update #114
thank you perhaps we should throw a wankle diesel in the ring?:laughing:
   / B3200 Vibration Update #116
I talked to the mechanic that changed the timing on my 3200. He said the timing needed to be advanced 8 degrees because the pump was injecting the fuel too late in the compression stroke.
   / B3200 Vibration Update #117
8* late as a long way off. It must have run real poorly. Should of had poor power output also?:(
   / B3200 Vibration Update #118
I was not working it hard due to it being brand new so power loss was not really apparent. It did run fine after being warmed up. It runs even better now though. I'm happy with the out come.
   / B3200 Vibration Update #119
Was this done by the dealer?
   / B3200 Vibration Update #120
Yes it was dealer serviced with about 5 hrs on the clock and of course under warranty.
LeeBoy L250 (A53317)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
2018 VOLVO EC480EL EXCAVATOR (A52707)
2018 VOLVO EC480EL...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A55852)
2015 Ram 5500...
UNUSED FUTURE (3) AUGER SET (A57193)
UNUSED FUTURE (3)...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A55302)
Kubota SVL65-2...
