B7100 Restore Project Has Begun
   / B7100 Restore Project Has Begun #91
Nice pattern, 6mmbr! I'll have to keep my eyes open for Honda Pilot fogs.
JT - that's a really nice restoration, and I may "borrow" your grill guard idea, except I will have to omit the receiver hitch as the fwd PTO shaft will be going there.
How many gears did you have to replace in the transmission?
Was everything available new or did you have to repair anything?
I had to replace 4 gears, 2 bearings, and the 4x4 shifting fork slide. Replaced all the seals while it was apart. That was 650.00 worth of parts. Everything was available from Kubota and my local dealer gave me a huge discount on the order. I also had to hone the lift cylinder and replace the O ring and add the up dated plastic ring. The cylinder had rusted from condensation during the 3 years of no use at the community college. All the major mechanic work that I have had to do has taken up the time that I would like to have been making improvements like you have to yours. Finally got the body painted today and hope to get most of it back together this coming week in between working on my son's truck. Still have to prep and paint the wheels then do the body work on the hood which will take awhile due to it's condition. Your headlights look really good. Do they max out the dynamo?
   / B7100 Restore Project Has Begun #94
Glad to hear you were able to get everything replaced and didn't have a casted part broken. Although it cost some, at least you know it's all solid in there now and it'll last until the "auction". (I keep telling my wife, "you're gonna have a great auction someday!)
According to my Datel Voltmeter, when running at mid-throttle or higher it generates 14.5 volts. With lights on, it drops to (approximately) 12.8 volts. If I drop to idle it goes to 11.98 volts with lights on, and 12.5 with lights off. Not sure how this fits into Ohm's law. Running two 55 watt bulbs. (ahem...anybody smart enough to do the math better show your work and the formulas...no work, no credit !) Moral of story: keep a good throttle when lights on!
I am sure you know this, but for the historical benefit of others reading your thread here, when you go to put new stickers on, spray the part with windex first and apply the sticker to the "wet" painted part. Move the sticker around to where you want it, then squeegee out the fluid underneath. It will be permanently fixed in place in 24 hours.
Waitin' for more pictures.....
..for your amusement, here is link to my LED flasher foray..
http://www.tractorbynet.com/forums/showthread.php?p=2740196#post2740196
Spring came too soon and time is getting away from me. I am still working on the restore and using the tractor at the same time. Just lack the hood and front wheels now. Began body work on the hood tonight since I got rained out from plowing with the TC40. I have aerated the yard with the B7100 using my 3 pt aerator that I built from a pull behind model. It can be used with the tongue for tow behind also. I have used the tractor enough to confirm that it isn't charging. The Dynamo is putting out 20v ac at half throttle but I am only getting 4v dc out of the rectifier. Have run it about 2 hrs and the battery dropped from 12.49v to 12.30 volts. Also have to replace the Hr meter which doesn't work. Looked on Ebay for rear hubs but everybody seems to be sold out at the moment. Both of mine have been broken and welded and no attempt was made to true them so I have rear wheel wobble. Seems as though the battery has been shorted out on the hood at some point as evidenced by the burnt area. I wonder if this could have fried the rectifier? I made a battery hold down since the Kubota one was long gone. And you may notice that I will be needing a seat cover also.
   / B7100 Restore Project Has Begun #96
Looking GREAT!!:thumbsup::thumbsup:
   / B7100 Restore Project Has Begun #97
Are you going to put new ag tires to finish the restoration?
Looks good
   / B7100 Restore Project Has Begun #98
If it's not one thing it's another, but you're making progress!
I think the hood is going to work out ok; little pounding, little bondo..it'll be great.
I got my hubs from Plowboys Equipment. The newer style hubs, but they still wobble a little - only noticeable when driving on the road.
2018 PRINOTH PANTHER T14R ROTATING CRAWLER DUMPER (A60429)
2018 PRINOTH...
2021 CATERPILLAR D3 LGP CRAWLER DOZER (A60429)
2021 CATERPILLAR...
light tower (A56857)
5ft Pull-Behind Rotary Tiller Tractor Attachment (A59228)
5ft Pull-Behind...
Crown Stand-On Electric Forklift (A59228)
Crown Stand-On...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
