Buying Advice Ballast Box vs Wheel Weights vs Filled Tires
   / Ballast Box vs Wheel Weights vs Filled Tires #41
I will deal with that if and when it ever happens. Good motto to live by. The ballast box is not something you are going to bang around. It just hangs there as weight. If it does ever happen, I will post back with some creative welding! Philip.
If your 3pt arms will spread a bit more you could weld a small piece of
Channel on each with a hole in them the size of a bolt on lower link pin.
Just idea in case it ever happens. I do like the box, I'd like make one like it.
You guys are an awesome resource. Thanks for all of the terrific feedback.
I'm more inclined to go with wheel weights if I can get them instead of loaded tires, mostly because I'd like the option of being able to remove the extra weight when I'm mowing the front lawn, especially since I'll be using R4's.
If I understand correctly, Kubota doesn't make wheel weights for their tractors, with the exception of one or two models. Is this accurate?
If this is the case, where would you guys suggest getting wheel weights that are the ideal size for the rear wheels on the B-Series tractors? It would be great to get make and model numbers if you've got them. I know a lot of folks are more apt to just jury-rig something, however I'd really like to find weights that are the ideal size for the rear tires I'd have and won't require any retrofitting to make them work.
Thanks again for all of the help,
John
   / Ballast Box vs Wheel Weights vs Filled Tires #43
Check with your dealer as I got the wheel weights for my BX2660 from the dealer, they also have them for my L5030 and M8540. I don't know if they are OEM, but they said they could get them.
   / Ballast Box vs Wheel Weights vs Filled Tires #44
I suggest you
a) don't buy a tractor with a fragile front axle, i.e. just avoid tractors with front axles that NEED load relief when the bucket is loaded to it's full capacity.
{Same with front tires, R4s are load rated higher than R1s}
b) Plan for storing with SOMETHING on the back of it, whether that is a mower, tiller, hoe, whatever.
You will almost certainly MANY TIMES finish the day and want to NOT mess with taking off whatever is on the back.
c) Load the rear tires ANYWAY - add a USEFUL implement on the back if/when you need it, but don't waste money on buying or lugging around dead weight.
This doesn't have to be an "or", or" it can be "and", "and".
The "not" is a tractor with a fragile front axle and light rated front tires.
As far as "don't buy a tractor with a fragile front axle", I wonder if there is such a thing. I'm on my third tractor (went from a 19 HP Deere to a 35 HP Deere) and all three had loaders. The tractor and loader manuals were pretty specific on the need for rear ballast.
My machines were all CUTs and I can't say I've ever read (or even seen) manuals for full sized UTs, but I'd wager those manuals would read the same.
As far as " but don't waste money on buying or lugging around dead weight", the ballast boxes provide for a lot of weight in a very compact size...can't see calling that "dead weight". That compactness is quite handy in close quarters (meaning I haven't hit anything with it yet...can't say the same about the rear blade or rotary cutter).
Also, that ballast box is one of the easiest of implements to rig to the 3PH (mine is kept on a roll around dolly).
   / Ballast Box vs Wheel Weights vs Filled Tires #45
John
So you would remove the wheel weights weekly for mowing ?
Hmmm, OK - if its OK with your back and your chiropractor, but there is something else you seem to be missing here.
Tearing up lawns comes MUCH MORE from making tight turns on wet grass/soil than what pattern tires are on the rear (or the actual ground pressure from WEIGHT).
It does seem to be that we are tempted to mow right into the corners and tightly around trees and shrubs, so the only solutions I can offer is to mow only when the ground is very dry or buy a Z-turn mower.
Ahh, buy the Z-turn anyway (-:
BTW, you could probably rig up some sort of a lift for the wheel weights to save your back, but it is still a weekly hassle.
   / Ballast Box vs Wheel Weights vs Filled Tires #46
Yep...pulling them manually would put you in the worst possible position for your back.
I've got two herniated disks...you cannot imagine the pain when they flare up. So, watch your back!!!
   / Ballast Box vs Wheel Weights vs Filled Tires #47
Well, I'm sure your numbers are different for my tractor... buy my ballast box weighs 1800 pounds. Using your numbers, that would remove 675 pounds off of my front end. But more importantly, it prevents my rear end from coming off of the ground when I am picking up a big load or ripping trees out of the ground. Keeping the rear end on the ground is the biggest benefit in my eyes.
If you NEED to lighten your front axle's load by ~675 or so then maybe 1800 lbs on the back is a good idea - one would have to know the axle's rating to know for sure.
My CLAIM is that the front axle shouldn't need load relief and the 675 is probably such a small percentage of it's rating that with the loader fully loaded you should be well within the margin without having to subtract ANY load.
The loaded R4s should provide adequate stability for loader (to full capacity) work.
I would rather have my next most likely implement on there anyway, not for rear ballast, just for the straight utility of having it there and not having to swap a dead weight off and on (-:
I know, Murphy tends to interferes with that idea, but there is a better chance that the next implement I need will be the last one I used than that it will be mere ballast.
So, how many loaders are out there that can outlift their tractor's front axle capacity ?
IOW, is front axle load relief a REAL problem, or just one that we can suggest to ourselves with casual observation and a little arithmetic ?
   / Ballast Box vs Wheel Weights vs Filled Tires #48
So, how many loaders are out there that can out lift their tractor's front axle capacity ?
I'd suggest most of us are more concerned about reducing wear and tear on the front axle, bearings, steering components, etc.; rather then a catastrophic failure of the axle.
That, and keeping the rear wheels on the ground.
Going back to the manuals of the tractors I've owned (Deere 670, 790 and current 4400), all three recommend removal of the loader when not needed. I did this on the 670 and 790 (for better maneuvering when mowing as much as lessening the weight on the front axle). The 430 loader is too big to leave in the garage (until I do some re-arranging), but I do drop the bucket (same reasons as the 670 and 790).
I'd also suggest this is more of a concern with front wheel assist axles over the straight beam axle of a 2WD tractor (read "Larger Utility Tractor").
That's what works for me and I intend to continue. What Reg does works for him, and I expect him to continue...just as other operators will do what they think best for their machines and situations.
BTW, Reg...what does your manual recommend?
   / Ballast Box vs Wheel Weights vs Filled Tires #49
John
A bit more info about your situation would help. If your "front lawn" is a landscaper perfect showpiece, you're going to have to be very careful using the B for mowing, with or without weights. R4's can easily put ruts in the ground when it's wet and leave skid marks on sharp turns. If it's a wide open lawn, maybe you'd be OK, but the more trim mowing you have, the more you'll want a "lawn mower" instead of a tractor. If you want that perfect lawn, you'd probably be happier with the turf tires vs. R4's, but that seems at odds with using the same tractor for dirt work.
On the other hand, my place, for example, is a former cornfield that we mow every few weeks with both a bush hog type cutter and a finish mower. It already has bumps and ruts, but from 100 feet, it looks like finished lawn just because we mow it frequently. If the occasional rut or skid mark doesn't bother you, the weighted B with R4's will do just fine.
I'd suggest you find out if you've got a dealer who will arrange to bring an R4 equipped B tractor out to your place for a FEL-mowing-digging demo, so you can find out directly what will work. Probably before winter hits up there. Good luck as your adventure unfolds!
   / Ballast Box vs Wheel Weights vs Filled Tires #50
My plan was to go the 55 gallon drum way. Those fancy boxes look real nice but I have extra 55 gallon drums and plenty of scrap steel and for $6 from tractor supply I picked up to 7/8" pins. I'm sure if I was to pick up some Kubotaish colored paint it'll look pretty good. I also have about 10 or 12 old bags of cement that were here when I bought the land. I'm sure they are only good for ballast.
U56 ELECTRIC FIRE PUMP MOTOR (A51406)
U56 ELECTRIC FIRE...
2018 KENWORTH T880 (A53843)
2018 KENWORTH T880...
2014 Nissan Rogue Select S SUV (A51694)
2014 Nissan Rogue...
(INOP) YAMAHA MOTO 4 ATV (A51247)
(INOP) YAMAHA MOTO...
2021 Bobcat S740 (A50123)
2021 Bobcat S740...
2016 Big Tex 24ft. T/A Flatbed Trailer (A50322)
2016 Big Tex 24ft...
