Band Saw vs Abrasive Chop Saw
   / Band Saw vs Abrasive Chop Saw #21
Never even crossed my mind there could be a difference in speed. Guess I got a blade I can't use because the saw I want to get is a different size. Sure would like to try the blade out before buying the saw though.
   / Band Saw vs Abrasive Chop Saw #22
Slayer, if it helps here's my experience on this -
'bout 10 years ago I found a 14" dry cut blade at Hazard Fraught - saw the speed rating, still wanted to know if it'd work, bought it on sale for $35 IIRC, went home, put it on a Ryobi chop saw (the fiber blade kind, around 5500 rpm) - put on my heaviest leathers, face shield, etc, then stood out of line with the blade as much as possible, cut some .120" wall 2" square tube - worked FANTASTIC - clean cuts, quick, accurate, etc...
Same with the next 20-25 cuts, then started slowing down (not the saw, the cuts), having to push harder, etc - by about 40 cuts it was DONE. Meantime, the leathers proved to be a good idea (within a BAD idea :D ) - between running too fast and being Hazard Fraught :rolleyes: the blade lost a few carbide teeth, couple lodged in my leathers...
I did go back to HF for "one more time", but those blades were GONE and I never saw 'em again.
I STILL don't have a dry cut saw, (retired now, smaller "toy fund") but when I do it'll be the better model Evolution. Stronger base, better vise, less "homeowner" gimmicks. It's this one - note the better price in SECOND link...
Evolution Power Tools EVOSAW38 15-Inch Steel Cutting Chop Saw - Power Circular Saws - Amazon.com
Evolution EVOSAW38 | Evolution Power Tools | Evolution 15
I "kicked the tires" on one at my local dealer (they wanted $470 for it and wouldn't come down) - unlike a few others I've seen, NOTHING about it seemed "homeownerish", just a solid tool... Steve
BTW, I think that if a HF blade running at 3 TIMES its optimum speed in a so-so Ryobi saw lasts for 30 cuts, a REAL blade on a REAL saw at CORRECT speed with a GOOD hold-down system should be a LOT longer-lived...
   / Band Saw vs Abrasive Chop Saw #23
I got a project that will probably require 8-12 mitre cuts, so I may just go ahead and try it, making sure I stand to the side when cutting. Thanks for the input.
   / Band Saw vs Abrasive Chop Saw #24
You're welcome; 'nuther warning - gentle to medium STEADY pressure, and if your hold-down setup isn't fort knox, maybe add a welding clamp so the piece DOESN'T MOVE - binding will dislodge MORE carbides... Steve
   / Band Saw vs Abrasive Chop Saw #25
BukitCase - your second saw link at discount steel is where I bought mine.
They also had the best deal on 15" replacement blades too.
   / Band Saw vs Abrasive Chop Saw #26
Started with a Makita chop saw and it did what I needed for tubing and light angle.. Moved to a small Ellis bandsaw it was heaven. Then I did some horse trading with another Rep and got an Evoulution Comnpound Mitre metal saw. I use it for wood and quick mitre cuts on aluminum and steel. I like both equally but would have no problem going back to a chop saw if space and need demanded. But if you cut 1/4" or thicker steel, You will have your work cut out for you with a chop saw. Buy a lot of blades and plan to spend some time with them.
   / Band Saw vs Abrasive Chop Saw #27
Carl, I got a reconditioned Skilsaw metal cutting saw for around $100. The saw is great. I like it much more than the Milwaukwee.
SKILSAW SPT78MMC-�1 15 Amp Outlaw Worm Drive Saw for Metal, 8" - - Amazon.com
Hard to cut small stuff accurately with it but I will make a raised track to let it run on for things like that. I hate using an abrasive saw. The Skilsaw is my go to method right now for straight cutting plate. I like it better than plasma. I like my horizontal bandsaw for things small enough to fit in its vise.
Ken
   / Band Saw vs Abrasive Chop Saw #28
I have decided on that one too... thanks for posting the discount steel website... that's a great price with free shipping too.
Dave, how is the hold down clamp? Solid?
   / Band Saw vs Abrasive Chop Saw #29
Dragon, the amazon link has a good pic of the vise setup - notice that the stationary jaw doesn't require a wrench - also, that saw has a quick-close pawl that some of the others don't have - see the top pic for that... Steve
   / Band Saw vs Abrasive Chop Saw #30
I put a chop saw blade on a mitre saw once and hated it. For most things I cut with a horizontal band saw. Got a portaband also. Some things just require a cutoff wheel on the angle grinder though. Got 3 4.5" angle grinders, one with a grinding wheel, one with a wire wheel, one with a cutoff wheel.
I'm thinking of getting one of those mitre saws with a metal cutting blade. I've got one of the blades to test in my wood cutting mitre saw. If I like that I'll probably get the actual saw made for it. I want that to make more accurate angles than the band saw.
Definitely need something to hold up long pieces in the horizontal band saw. I was given a roller stand made for a mitre saw. Too tall for the band saw. With unlevel dirt floor I needed a way to adjust the height. I had just recently found an old floor jack that still worked. Welded a piece of rectangle tube to the floor jack to raise it up about a foot, and welded the top of the roller stand to that. With long heavy pieces I can place one end on the band saw, then get the other end on the roller and jack it up until it's level.
I made a couple of 14" x2" roller tables for my bandsaw. I'd LIKE to get an
Ellis but I'll probably just stick it out with the 7x12 import saw I bought 20 years ago.
3 Point Hitch Boom Pole (A51573)
3 Point Hitch Boom...
JOHN DEERE Z960M LOT NUMBER 102 (A53084)
JOHN DEERE Z960M...
2014 International WorkStar 7400 Truck, VIN # 1HTWGAAR3EH765319 (A51572)
2014 International...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
