Basement Plumbing Question from non-plumber
   / Basement Plumbing Question from non-plumber #1
miltrade
Virginia
JD 4200
I recently bought my home (13 months ago), which was built in 1989.
In the unfinished basement, there is no roughed in plumbing at all. The whole home is on a well and septic-system, so all the water and drainage pvc and copper is run overhead, both coming in from the well and draining out to the septic.
Is it possible to add a basement bathroom in this case? By code, it has to be done by a licensed plumbing contractor. Would the contractor run the drainpiping under the concrete? If so, how do they tap into the existing drainage to the leachfield, which is all overhead? I know in homes on public water, the drainpipe is in place as the foundation is laid and runs down and away. How does a basement bathroom drain work if it has to go UP to get to the existing drainage?
Has anyone done this to a home on septic and well? How much did you pay?
THANKS.
   / Basement Plumbing Question from non-plumber #2
I don't believe your septic field is the issue. The issue is where your sewage drain leaves your house. In your case, it sounds as if it leaves above the basement, which seems very odd to me, but I didn't build it.
You can still put a bathroom down there, but you'll need a pump. A buddy of mine did the exact thing. His sewer hookup was in the basement, but there was no rough-in for a bathroom. Rather than tear up his basement floor, he got a pump and ran his plumbing overhead (above the drop ceiling) to the drain pipe leaving the house. These pumps are common enough that any home supply place should have them. I don't know what they're called or anything about them, but I know they exist.
I would suggest buying the best, most highly warranteed one you can find. That's not something you want to be replacing or failing in any way.
Also, I'm not sure where you got the requirement for a licensed plumber to do your installation. I can't believe there is any way that is a law. What you do to your house is your business. As long as the work is up to code when you go to sell it (if you plan on ever selling), you're good to go.
Thanks. I know relatively little about plumbing, other than general principles and of course I can install toilets and sinks etc.
So, even when they are building homes on well and septic, with a subterranean basement, not on a slab, they still usually run the drainpipes below the foundation? Thanks.
   / Basement Plumbing Question from non-plumber #4
My neighbor just had a bathroom added to his basement. He installed one similar to this. Saniflo I believe he bought the whole system at Lowe's.
   / Basement Plumbing Question from non-plumber #5
Sanitary for all Inc.
5 Columbia Drive ste 472
Niagara Falls NY 14305-1275
Tel-800-363-5874
E-mail: sales@saniflo.com
Web site:www.saniflo.com
This company has everything to install a below ground
toilet or complete bathroom. I've had one for 6 years and have had no problems. I have toilet, complete shower and
wash basin, all run off of this unit. You only need a 3/4"
line to existing sewer line or septic tank. Of course water
supply lines to the fixtures. Nice units.
Good Luck
   / Basement Plumbing Question from non-plumber #6
The type of pump you need is called a sewage ejector and needs to be sized according to how much water you will be generating as well if you need to move liquid or solid waste. In addition, generally those pumps have an alarm system that will beep if there is a failure, this is to prevent raw sewage leaking out from your pipes into the basement. I have had a sewage ejector in my last house for 3 years and have not had any sort of problems.
The installer did tell me that the pumps are usually good for 5 - 10 years depending on usage.
Hope that helps.
Derek
   / Basement Plumbing Question from non-plumber #7
My basement has a sewage pump in it. The pipe goes out of the house about 3 feet up the basement wall. The water goes into a holding tank in the concrete floor. When it's full it acts like a sump pump. It trips the float, pumps the water and has a flapper in it to keep the water going 1 way.
Here's an even easier solution
http://www.libertypumps.com
   / Basement Plumbing Question from non-plumber #9
I had the same challenge, the 4" sewage was overhead in the basement when we decided to finish out the basement. At first I considered the all in one unit, but didn't like the design of the unit and what I would have had to do to finish out the bathroom. In the end, I cut concrete to set a basin for a pump, and cut for a drain for a shower, commode, and sink. The builder had a clear vent all the way to the basement, which helped with code issues. The basin/pump (Little Giant was my pump/grinder of choice) sits 14' from the bath so concrete cut was minimal. I paid $100 to rent a jack hammer and concrete saw. The lift on the pump was adequate for the 10' ceilings in the basement. A check valve was needed, and the line from the pump was isolated with a short rubber tubed. (keeps the "clunk" from being heard when the pump runs. Four years later, even with two teenage boys, no problems. All together, less then $1000 plumbed the bathroom, and less then $1000 in fixtures - commode, shower, sink, lights, mirrors and vanity. It all amounted to a very finished look. Let me know if you need details or pictures of the installed basin and above ground plumbing & good luck!
   / Basement Plumbing Question from non-plumber #10
Another option is to run the plumbing under the slab to the outside, then a "sewage pit" with a pump/grinder which then would go directly into the septic tank. This way, the pumping station and any associated odors wil be away from the structure. This way also uses standard piping and fixtures inside the house. Messier, yes. More concrete work, yes. But usually a much nicer install when done. A jack hammer and a trencher rental would easily handle the job. I would seriously question the need for a "licensed plumber" to do this. Some places allow you to pull a homeowner permit whereas some might require you to take a test after studying whatever they provide you with.
And, I think it was Bird, said it best "plumbings easy. Pressure goes where you want, stuff goes downhill and don't bite your fingernails while you're working on it". /forums/images/graemlins/grin.gif
   / Basement Plumbing Question from non-plumber #11
Where i lived in Wisconsin, we had to have a licensed plumber come in to change out a kitchen sink. Same thing with Electric work, all work has to be done by licensed electricians.
   / Basement Plumbing Question from non-plumber #12
I don't understand how the government can tell you what to do in your own home. How will anyone ever know who installed your kitchen sink or ran that light to your basement?
The idea of the government telling me I have to pay someone else to replace my kitchen sink rattles me.
Nobody would know until possibly when you sold your home and a knowledgeable inspector spotted the work, IF they spotted it. If it is the buyer's inspector they may very well ask if this work was done to code and/or by permit. But the chances are slim I would imagine.
   / Basement Plumbing Question from non-plumber #14
I don't think it is the government as much as it is individuals filing litigation, insurance companies and juries awarding big money because the insurance comapny is paying. Most Firemen in large Fire Departments are either certified or licensed building inspectors. Have an incident and let one classify the incident as --- faulty --- plumbing-electrical installation and see how fast insurance companies can run. So, that electrical connection to the basement could cost a great deal. Providing verbal information on how to do something can also leave one liable. I like the USA (Us Sue ALL).
   / Basement Plumbing Question from non-plumber #15
Please do not "pump" directly into the septic tank. By injecting sewerage with high energy into a conventional septic tank you create turbulance. This then can then put into solution undesirable solids that may find their way out of the outlet tee, and into your leaching field. Their are effluent filters such as the Zabel filters which help prevent such escape of solids and semi floatables such as seeds, but even these need to be checked every 6 months. Usually we pump indirectly to remove as much surcharge and energy from the flow. Speak to a local plumber/engineer with knowledge in code in your area before adapting your septic.
Dave
   / Basement Plumbing Question from non-plumber #16
Doesn't that really depend on the "how's and where's" moreso than a don't do that statement?
2018 FREIGHTLINER M2 26FT BOX TRUCK (A59905)
2018 FREIGHTLINER...
2019 Peterbilt 579 SLEEPER (A59905)
2019 Peterbilt 579...
2013 TEXAS PRIDE LAY FLAT HOSE TUGGER TRAILER (A58214)
2013 TEXAS PRIDE...
2017 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2017 KOMATSU...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
UNUSED DSBREAK DS140A HYD BREAKER W/ BIT (A60432)
UNUSED DSBREAK...
