Best implement for snow removal
   / Best implement for snow removal #41
I moved 42" with the 8N with a 6' scraper blade.
I wouldn't even know how to go about doing that. That would be like a foot higher then most blades. How did you do it, just curious?
   / Best implement for snow removal #42
Best implement for snow removal ????? Airplane------to Florida. I just had to say that.
   / Best implement for snow removal #43
I run a 10 foot fisher plow on one tractor and a 8 foot frontier blower on the front of the other tractor. 9 times out of 10 I use the plow. The plow is faster and cheaper and as long as you start the year out by pushing your banks back you shouldn't have much trouble, If banks get out of control put the bucket on. The last thing is with out a cab plan on eating a lot of snow if you use a blower, when Im done with the blower my tractor looks like a snow bank on wheels.
   / Best implement for snow removal #44
I use a rear blade and FEL with good success. I also have rear chains which though very expensive I would not be without even with fluid in my tires. I can go through any snow with them on even when we get some of the dreaded ice underneath it first. The chains are heavy and some work to put on so once I put them on they stay on until about March. A blower would be nice, but limited use and something else to maintain.
That is an AWESOME looking jeep setup you have there :thumbsup: For heavy snow removal, the problem comes down to weight, or lack of weight, with a small vehicle like that. I don't think you'd have a problem with clearance though :D
   / Best implement for snow removal #45
Thanks bud. She weighs in at 5,200lbs. I haven't had traction be a problem yet... but I'd put some chains on her if it was an issue. 4-6" of snow is normal here...10" might happen once or twice a year. Everything's a compromise... fat tires tend to float over the snow instead of digging down... but they sure make "ramping up" the snow easy.
Plowing 3 - YouTube
   / Best implement for snow removal #46
I picked the blade up and pushed it on a angle towards the edge of the drive way as far as a could. Then I kept dropping the blade down a bit and pushed it more until I was down to the driveway. The worst part is getting a start, you need to get a area so you can move up and back. When I got done I had a very narrow path that was wide enough for a vehicle.
   / Best implement for snow removal #47
Just my .02Cnd
The Guy who plows my long S driveway uses a farm tractor with chains & cab and has a pickup snow blade on a homemade frame attached to the bucket of the front end loader and a left/right hydraulics to the blade and normal up down on the loader it looks like heck but works very well one main advantage I can see is he can push a bank very high 7-10ft
Weewilly
Any comments what works best to keep your gravel ON the driveway (I know asphalt works the best :) ). Can you put skid shoes or plates on a front or back blade? Or maybe even on a FEL?
   / Best implement for snow removal #49
You can install skid shoes on anything...might take a bit of fabrication or welding. This includes your loader bucket.
When I plow with my bucket, I keep it curled back. That, in most cases, keeps the front lip of the bucket about an inch off the surface.
   / Best implement for snow removal #50
I use a drag type snow blower, often called an inverted blower.
I have no trouble driving thru the snow and then let the blower get rid of it.
Since you are going forward you have many gears to choose from so you can find a speed to match the blower load on the tractor.
I built the drag blade on the back of the blower to pull snow away from shop doors. It is built out of 1/2" plate so I also use it for leveling gravel and ground.
Dave M7040
2008 KOMATSU D51PX-22 CRAWLER DOZER (A60429)
2008 KOMATSU...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
1993 Ford Pick Up (A59814)
1993 Ford Pick Up...
1999 GMC C7500 S/A Dump Truck (A59230)
1999 GMC C7500 S/A...
EXCAVATOR JACKHAMMER (A58214)
EXCAVATOR...
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
