Brake controller installlation
   / Brake controller installlation #11
I have the Prodigy in my rigs also. they do work great
   / Brake controller installlation #12
Since you have a Dodge truck, there is a plug under the dash that is pre-wired for a brake controller. You can buy the adapter for about $10 that plugs into that adapter and wire it to the brake controller. You may need to put a fuse in the power cable going to the battery but some already have the fuse in the holder.
On my 03 Ram 1500 I ran a new wire from the battery to the 7 pin connector because the factory wire was 12 gauge and I was getting 12.5 volts at the 7-pin. I ran a 10 gauge and it jumped to 13.4 volts.
All my Ford/GM trucks had to be completely wired.
   / Brake controller installlation #13
i think alot of it depends on if it had a factory tow package or not, as to if it was pre wired or not.
incedentally.. on my dodge ram.. i ALSO ran a seperate parallel brake wire to help out the one in t he truck harness..
soundguy
Found the harness that came with the truck. Joined the red, white and blue wires but need to go get a 20 amp breaker before I can finish the job.
Thanks again for the pointers.
CB
   / Brake controller installlation #15
All Dodge trucks have the wire harness under the dash. The tow package adds the 7 pin connector to the rear and the class III hitch.
Also, if you can't find the red wire at the rear of the truck, sometimes it was cut-off under the truck, directly below the drivers side seat.
   / Brake controller installlation #16
i know the plug would be there.. but if the truck was not specced with a tow package and no 7 pin plug is at the rear, will the actual wire harness be ran back there? I know there is a tap for a 4 pin flat.. and with that and power and brake power you have all you need.. etc..
soundguy
   / Brake controller installlation #17
Soundguy said:
i know the plug would be there.. but if the truck was not specced with a tow package and no 7 pin plug is at the rear, will the actual wire harness be ran back there?lP
I found most Dodge trucks have the charging and brake signal wires all the way to the back but some have those two wires (red and blue) cut right under the drivers side seat along the frame rail.
   / Brake controller installlation #18
at least it's better than the old days of having to tap the brak switch.. or get one of those converters if you have the backwards style switch.. :)
   / Brake controller installlation #19
Give it a break. Ford and GM along with all the imports have had the wiring in the about the same time Dodge did.. Get off the dodge band wagon....
Chris
   / Brake controller installlation #20
Chris
Sure they did, when you PAY EXTRA for the towing package. It was not on every truck like the Ram's/Dakota's.
Sterling 9500 (A56438)
2019 Peterbilt 520 Heil Side Loader Garbage Truck (A55973)
2019 Peterbilt 520...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2006 CATERPILLAR 420E BACKHOE (A59823)
2006 CATERPILLAR...
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
1992 Norris Long Basket Trailer (A60460)
1992 Norris Long...
