California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,647
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
Now I am surely showing my age, but what in world is a "wheelie bar" ? Right up until I came back to this thread, I would have had visions of a drinking establishment, probably with girls my mother warned me about hanging out.
The top of the red line can move back toward the immovable anchor if you apply enough torque. Imagine parking a tire on the tow cable, chaining the cable to the tire, and letting out the clutch.In order for the nose of the tractor to lift, the red line (attachment point) has to pivot forward. It can not come forward because it is chained to an immovable object.
Well, I guess one way to look at this is to consider if a tractor could flip if the rear wheels were solidly frozen to the ground. I suspect that it could. What makes the above diagram problematic is the assumption that the pivot point for flipping is the center point of the rear axle. I suppose that could be the case - but the pivot point could be the point where the rear tires contact the ground. In that case, the pulling force is above the pivot point, and the force could, if great enough, pull the front of the tractor up.
In my illustration, scenario A uses the axle as the pivot, and the rotational force pushes the front down. Scenario B uses the bottom of the tire as the pivot point, and the rotational force pushes the front up. Granted, the mechanical advantage in scenario B makes the required force to flip much greater, but it looks like the physics says it could happen.
I'll bet someone in the world of pulling tractors can describe this better. They wouldn't need wheelie bars if a low anchor point would do the job. And I don't think there is a difference between a rolling start, and applying the torque standing still.
