Broken pto housing
   / Broken pto housing #21
Very good news indeed.
   / Broken pto housing #22
Well I got lucky as the damage was contained to the cover itself. The dealer wants to replace two bearings fluid and filter just in case there's any metal floating around so about 400.00 the bad news is I've gone almost two weeks and could have fixed it myself in three days. I'm thankful though and I'll never forget to release the drive shaft from the tractor again. Thanks all.
Turned out about as good as you could have hoped for,good luck.
   / Broken pto housing #23
Glad you got it sorted out.. no point in beating yourself up about it, we all make mistakes. I thought I'd never leave the ROPS up when trying to park the tractor in the garage too, three attempts later (not on the same day at least) I still can't make it fit!
Sean
Hopefully once will be enough to remind me forever. Luckily the rops on the bx fits the garage nicely, if I had gotten anything bigger I'm sure I'd have done that too.
   / Broken pto housing #25
I wouldn't even quibble about those bearings. Do it, pay the bill, and drive off into the sunset knowing it's all good as new.
Did Kubota insurance cover it?
Yes the insurance covered it. I just got it back and the bucket won't raise or curl at idle. Only when throttled up. Anyone have any idea why? They put new fluid and a filter in, they also had the engine out to replace a drive shaft boot that had torn.
   / Broken pto housing #28
May have air in the system. Run all the controls to full lift and back. Hope this works.
   / Broken pto housing #30
That IS odd.. it sounds like there's a small internal leak in the hydraulic system. With hydraulics, there is no pressure in the system (very minimal pressure anyway) until there is a resistance to the flow created by the pump. The pump may not create enough flow at idle to overcome the leak. When you rev it up, the leak isn't big enough to allow all the fluid to bypass before building pressure to raise and curl the loader. It's like the relief valve is stuck partly open.. or something similar. Will the 3-point hitch do the same thing? You might have to put an implement on it to get enough load to check.
Sean
19008 (A56859)
19008 (A56859)
ALLISON TRANSMISSION (A55745)
ALLISON...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2013 Chevrolet Silverado 4x4 Service Truck, VIN # 1GC2KZCGXDZ156404 (A57453)
2013 Chevrolet...
2017 Ford Explorer AWD SUV (A56859)
2017 Ford Explorer...
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
