Tiller Broken tiller - what went wrong?
   / Broken tiller - what went wrong? #11
" </font><font color="blue" class="small">( )</font> <font color="blue"> </font> I'll wait until the rains come in Nov or Dec and then use a middle buster to turn the soil before running that spindly-tined tiller around the jobsite. Hope to avoid the problems mentioned in this thread. The RS1200 is way too flimsy to try tilling now. "
Interesting you say that. My RS1400 seems indestructable. I worry about tearing the tractor up before dammagine the tiller..
   / Broken tiller - what went wrong? #12
Re:"tearing up the tractor". That's why I'm adding a slip clutch (not included on the PTO shaft that came with the RS1200) before going tillin'.
   / Broken tiller - what went wrong? #13
</font><font color="blue" class="small">( Re:"tearing up the tractor". That's why I'm adding a slip clutch (not included on the PTO shaft that came with the RS1200) before going tillin'. )</font>
Did it not at least come with a shear pin??
   / Broken tiller - what went wrong? #14
I cant find one.... I'm just real carefull untill I fit it with a clutch.
   / Broken tiller - what went wrong? #15
Funny, a local shop told me that no type of protection is needed on a tiller being it will just hope over objects it hits. After reading everything here I did take her word for it so I have not used my tiller. I need to shell out the money for a new drive shaft with a shear pin or clutch..
   / Broken tiller - what went wrong? #16
Well, I have noticed that when a lower gear, if my tiller hits something hard, it will push the tractor, skidding the tires.... Not a good feeling, especially on a hill...... /forums/images/graemlins/blush.gif
   / Broken tiller - what went wrong? #17
</font><font color="blue" class="small">( cant find one.... I'm just real carefull untill I fit it with a clutch )</font>
How does the driveshaft attach to the gearbox or input shaft on the tiller.. that's where I'd look for a smooth shaft / yoke coupling and a bolt ( shear bolt)..
Soundguy
   / Broken tiller - what went wrong? #18
</font><font color="blue" class="small">( I cant find one.... I'm just real carefull untill I fit it with a clutch. )</font>
I don't think one could be careful enough? Unless your in territory that has been tilled a bunch of times you just don't know what your going to hit. Like Soundguy said, look right at where the PTO shaft hooks to the tiller. It has to be secured somehow and more than likely you have a shear pin real close there. I just can't believe any manufacture would be in their right mind to not at least put a shear pin in?
murph
   / Broken tiller - what went wrong? #19
Here is the page for the tiller manuals that are part of the Buhler Family.
Buhler Manuals
Go there and you can download the complete manual.
murph
   / Broken tiller - what went wrong? #20
Interesting. I have a 72" KK tiller, it's gear drive. I've hit T posts and tons of stones and have never broken a tine. I've had the slip clutch adjusted too tight and have stalled the tiller and the tractor. I did some cemetery rehab work and tilled up a few stones that were sunk out of sight. At least 1 was broken by the tiller.
I've easily tilled 50 - 100 acres in the past 7 years with this machine, the sheet metal is dented all to heck, but the thing just keeps running, no issues what so ever.
2004 JOHN DEERE 160C LC EXCAVATOR (A52709)
2004 JOHN DEERE...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
2015 Haulotte 5533A (A53316)
2015 Haulotte...
Parker 6255 Gravity Wagon (A59814)
Parker 6255...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
