patrick_g
Elite Member
LetsRoll said:Bernie, the switch that I used allowed me to vary the speed ranging from full power to almost very little air was coming out of the blower housing. The first dimmer switch that I tried, it wouldn't do nothing at all. Looking at Lowes website, the switch that I used suppresses the radio frequency. The other switch I think just lowers the voltage. Which is why it wouldn't do anything.
The RF suppression is to reduce radio interference (static it causes on nearby radios) and doesn't directly effect the unit's motor controlling.
It doesn't actually control the voltage.
It turns the power on and off so that the average time of on vs off provides a variable "duty cycle" which runs the motor at varying speeds.
For the other technogeeks (I can't be the only one!) the unit that suppresses RFI (Radio Frequency Interference) has a circuit that turns on the power to the load as the AC waveform crosses zero volts (so, no sparks so to speak) and then switches off as the current flow crosses the zero point (and again no "sparks.") This is a better way but costs a few more cents in components to build the unit.
Turned all the way up the unit just passes the applied AC power. Turned down it passes only a few cycles of AC out of every several so the average power applied is controlled from near zero to 100%. This is also the way variable speed (corded) drills and such are controlled. Cordless drill controls are similar in concept but different in circuitry.
Pat
