Bush hog blade stopping
   / Bush hog blade stopping #81
I was mowing grass with a 5 foot light duty King Kutter brush hog using a 40 horsepower NH tractor. It cut well in areas I had cut earlier this Spring but when it got into 2 foot tall grass (not that thick) it caused the blade to nearly stop but enough it did not cut at all. The mower has always been greased, the shear bolt was not damaged or broken. The blades are dull. When I would get back to the prior cut grass the blades would pick up speed and cut again but it had nothing for the taller grass. The tractor was moving at slow speed with engine RPM near 2500.
The problem is most of the grass is tall as my main tractor and mower have been down for 3 months waiting for an odd sized O ring. Really need to mow the tall stuff with what I have. Any thoughts or suggestions?
Something doesn’t seem right here. I used to have a small 20 hp JD tractor with only 17 pto hp. It would never big down in 2’ grass and weeds with a light duty 4’ cutter. That 40 hp tractor should have no trouble with 2’ grass and weeds.
   / Bush hog blade stopping #82
IMHO you would need to crawl cutting 2 ft weeds
with the dull blades. Your blades have to be really
dull to slow down like that. Its amazing how sharp
blades and slow speed will really cut them weeds!
willy
2025 CATERPILLAR 255 SKID STEER (A60429)
2025 CATERPILLAR...
(2) 330 GALLON POLY TOTES W/CAGES (A60432)
(2) 330 GALLON...
UNUSED RAYTREE RMDB82-DIGGER HYD BACKHOE (A60432)
UNUSED RAYTREE...
2016 PALADIN 22197MM SWEEPSTER 97" HYD BROOM (A60429)
2016 PALADIN...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
UNUSED FUTURE FT-FB30 HYD FELLER BUNCHER (A52706)
UNUSED FUTURE...
