Can I repair bush hog sheet metal with stick welder?
   / Can I repair bush hog sheet metal with stick welder? #41
Why pay $80 an hour? He likely has a minimum charge of 1 hour even if the pro is only there 10 minutes. Those patches you need to add are not structural in nature at all. Based on what I can see in the pics even less than ideal welds will hold perfectly fine. Preventing burn through is your biggest hurdle which should be reasonably easy on 16 gauge (or thicker metal) with stick. Less than 16 gauge is asking too much though of the stick process (but still doable with a backer plate of copper with care).
5/64" 6013 with electrode negative would be my first choice (or AC polarity if that is all you have). 5/64" are hard to find but do not flex all over like a 1/16 diameter will so I love em for applications when mig is unavailable. It is worth having a pound of these around.
1/16" 7014 would be my 2nd choice (I mostly hate all 1/16" diameter rods but 7014 runs so darned easy it makes this one 1/16 diameter rod tolerable). Again worth stocking a pound of these.
3/32" 6010 or 6011 would be my 3rd choice. Move real fast and jump around to utilize the fast freeze properties or you will burn through with that forceful arc of either.
3/32" 6013 electrode negative would be my 4th choice.
In short I would trial and error any of these 4 in my bags of tricks and see which worked best and make the best of it. Do not expect prettiness but functionality. Frankly that ole cutter is not pretty anyhow in its current condition.
With the way you have that bush hog hanging you can even get to the patches from both sides so use that to your advantage too. Weld from both sides or to use a scrap of copper as a backing plate which will help prevent burn through too.
Personally, I would not use 7018 on this thin of stuff as even 3/32" 7018 diameter will burn through the thin sheet metal much too easily imop.
   / Can I repair bush hog sheet metal with stick welder? #42
I repaired this bush hog for a guy I used to work with, You can see the patch on the side in the 1st pic and some of the welding where I had to weld up cracks and some small holes in the unit. All of this was welded with 1/8" dia. 7018 rods. with a Miller Synchrowave 200.
   / Can I repair bush hog sheet metal with stick welder? #43
   / Can I repair bush hog sheet metal with stick welder? #44
Nice work on the JD cutter repair, but that appears to be a heck of a lot thicker metal (3/16" thick or more) than the OP is trying to repair. No reason 7018 would not work fine on 3/16" thick metal without burn through.
   / Can I repair bush hog sheet metal with stick welder? #45
That's a very good idea. I found a guy that will come here for $80/hr, has all the mig stuff on his truck. I doubt it would take him an hour to do this if I get everything prepped.
O.k., BeezFun, I'll just go ahead and say it. You may never have a better opportunity to justify getting that mig setup that you've been half thinking about for the last few years! :laughing:
   / Can I repair bush hog sheet metal with stick welder? #46
The unit metal was just a little thinner than 1/8".....like about 12 gauge. I used 1/8" plate for the patch on the bush hog.
Thanks, I planned to do some tests once I cut an old piece out and can weld it to the patch material. Haven't used 7014, I'll get some and give it a try, storing 7018 is a pain. I've got a good bit of experience with 6013 too, so I'll see how that works. Yeah having it hanging up in the air makes it easy to work on, I'll probably cut out the bad areas with it hanging, then lay it down so I can weld in position.
I like your thinking. Problem is I have to learn how to use it, and don't want to learn on something that I have to look at for the next 15 years. I've been watching for used mig welders, if I see a Miller 252, I'd probably pick it up.
Nice job, he really did a number on that thing.
   / Can I repair bush hog sheet metal with stick welder? #50
Harbor freight has a wire feed fcaw welder for 109.00.
Buy it, use it once and throw it away. If it doesn't break use it for years and save money. At 90 amps it will be perfect for that thin metal up to probably 3/16 on single pass. For something non structural even a first timer can fix that Bush hog.
Pull at an angle and keeping the puddle about. 1/4" behind. Easy peezy.
2018 JOHN DEERE 410L BACKHOE (A52706)
2018 JOHN DEERE...
2007 Ford Focus Hatchback (A51694)
2007 Ford Focus...
2018 Ford F-250 Reading Enclosed Service Truck (A53422)
2018 Ford F-250...
New/Unused Root Rake for CFG Mini Excavator (A54865)
New/Unused Root...
New/Unused CFG Industrial MX12RX Mini Excavator (A54865)
New/Unused CFG...
2015 Ram 5500 Versalift SST-40NE 40ft Sign Bucket Truck (A55852)
2015 Ram 5500...
