Can lights and Ceiling Fans in a New pole barn?
   / Can lights and Ceiling Fans in a New pole barn? #21
...While they are fine for certain aplications, this isn't one of them. Just say no to can lighting in your shop.
Eddie
I agree. I have can lights in my house and they are only "bright" directly under the light. The rest of the light is diffused, or indirect. Not very conducive to lighting up a work area.
   / Can lights and Ceiling Fans in a New pole barn? #22
If I was planning the setup and wanted to work under incandescent, I'd make one area my main work station and light it with the incandescent. Then at least I'd have an "incandescent zone" that I could bring things to, to work on them in light I prefer. Most of the cans limit you to a 60 watt bulb, so depending on the height, you'd need 2 or 3 per station. Spread them out a little to cut down on shadows getting in your way. If I needed 3, I'd look into placing them into a triangle for instance. Put the switch for those lights right at the work station, maybe under the bench. A double size box that will hold a switch and an outlet is handy-never can have too many outlets. No reason you couldn't have multiple stations if you had something like a drill press or a grinder for instance. But the general lighting should be fluorescent like the other guys said.
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
Case skid steer wheels and tires (A56438)
Case skid steer...
2016 CATERPILLAR 330 FL EXCAVATOR (A60429)
2016 CATERPILLAR...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A56859)
2008 Ford F-250...
John Deere Frontier Quick Attach Pallet Forks (A59814)
John Deere...
2021 XCMG CV123PDU ROLLER (A60429)
2021 XCMG CV123PDU...
