Cleaning the fence row is fun now
   / Cleaning the fence row is fun now #41
Thanks so much, Neal. The text and photos are a great help. The only thing I still can't tell is about the vertical braces on the teeth. Do they butt up against the square tube or did you cut them to continue over the top of the tube?
Thanks again!
Mine went over the top. Only because I was using 3x1/2 and I thought it would look better and be stronger. I think TraderMark used 2" which could butt into it. I believe 2" would be plenty strong.
Yup, SmokeyMtnMan, it does look like I have your tractor doesn't it. Don't you just love that thing? Do you have the HST transmission? This is the first one I have owned. Don't think I will ever be without one again. Of course, I realize for certain jobs, other transmissions would be better, but for misc utility work, or loader work, it is great.
Is that your LandPride rake on the back. I presume that is to clean out the roots, ETC.
I thought I would start a new "believe it or not" thread in the owning kubota's. to show what this little tractor did, but I can not even find where you start a new thread now. I will show here the 7-1/2' dia x 27' long steel tank we loaded on a flatbed gooseneck trailer with this little tractor. I wouldn't have believed it if I hadn't done it.
If someone thinks it should be on a new thread, maybe they will tell me where to find the starting point.
Probably make you wonder if I dreamed I loaded that tank if I can't post a thread, doesn't it?
TBone
I was a little rushed last night & just posted the only picture I had of the grill guard. If you plan to build one & need more detailed pictures, I will be glad to try to get some for you.
   / Cleaning the fence row is fun now #46
Neal,
To start a new thread, just go to the section that you want to put it in and click open that section. At the top of the page you'll see a button that says "Post". Click on the button and start typing! /w3tcompact/icons/smile.gif
   / Cleaning the fence row is fun now #47
Thanks, Neal. I am definitely going to have to build one.
TBone
Tbone
Finally got around to taking some more pictures of the grill guard. Hope they help when you start your new project.
Will attach about 4 pictures,
1. Grill guard bolt attached
2nd Try, 2nd picture grill guard rear view
Recessed expanded metal
2013 VOLVO VNL (A55745)
2013 VOLVO VNL...
2013 Ford Edge (A54815)
2013 Ford Edge...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
cummins generator (A56857)
cummins generator...
2014 Gravely 60" Zero Turn mower (A55973)
2014 Gravely 60"...
2014 Ram 1500 4x4 Crew Cab Pickup Truck (A56858)
2014 Ram 1500 4x4...
