dfkrug
Super Member
- Joined
- Feb 3, 2004
- Messages
- 7,710
- Location
- Santa Cruz Mtns, CA
- Tractor
- 05 Kioti CK30HST w/ Prairie Dog backhoe, XN08 mini-X
Tom_Veatch said:......many finishers don't like vapor barriers - they don't get to go home as quickly. But it does result in a better, stronger slab.
Whether you mix the concrete yourself or buy it pre-mixed and delivered to the site, you are paying for a certain strength. In my opinion, it's pointless to effectively throw away much of what you've already paid for by allowing the concrete to dry out before it cures.
Or, to put it another way - a vapor barrier won't hurt, and it can help......
Very well put, Tom.
Contractors pouring slabs have some motivations that differ from those of
the customer. Plastic sheet under the slab slows down the finishing process.
Many contractors want to put sand on top of the plastic. This serves the
same purpose: absorb water from the wet concrete so it can be finished
sooner. Good for the contractor, but bad for the customer.
Some other things I have learned from designing and pouring slabs:
> Use a large aggregate! At least 3/4". In our area, contractors want to
pour slabs with 3/8" pea gravel concrete and have it pumped. Less work,
but weaker concrete. Pumpers here charge more to pump 3/4", too.
> A stiff slump of 3" or even 2" makes a very strong
slab. Stiffer and it is very hard to move; wetter and it is weaker. I have poured with 1.5-2" aggregate at 0" slump and it is the best, but must be
tamped into place.
> Use at least 5-sacks Portland cement/cy. Don't try to save a few
cents by going 4-sack.
> Use rebar and not wire fabric. #3s at 18" OC is plenty, but #4s cost only
a little more and are usually straighter and easier to place. #3s often
arrive bent.
> Plan for shrinkage. Many times it makes more sense to design the slab
as a floating slab, rather than tied to walls, footers, etc. This can reduce
cracking as the slab shrinks.
> You do not need expansion joints if the slab is indoors. (No heating from
large outdoor temp swings.) If the contractor wants to cut or trowel a lot of joints to control cracks, it may be due to cheating on one of the above.
> And, as mentioned, keep it wet. This means for days, not hours. This is
an area where contractors do not have the customer in mind either. I have
seen forms for stem walls being removed the same day as the pour. Bad
for the ultimate strength of the wall. Concrete is specified by its 28-day
cured strength. If it dries out, it has stopped curing! Don't let your new
slab cook in the sun!
