Creating a Lake
/ Creating a Lake #481
Eddie, was all the erosion at the culvert caused by water running off the road or was it from water trying to enter/exit the culvert? Are you trying to meter the amount of water going through this culvert?
/ Creating a Lake
Hey Jarrett,
I've cut my land and roads to catch as much runoff as I can, and direct it towards my two culverts. I also have a large open ditch that is at the end of my land that carries the bulk of my runoff.
This culvert doesn't catch as much as the other, but the flow was really strong after that rain and the clay wasn't compacted as good as it should have been. If I had some grass growing around the culvert, that would have helped too, but it was just too fresh of dirt.
The exit side damage was very minimal and I almost didn't do anything about it. I looked at it a few times before decideing I had enough sacks on the entrance side.
Eddie
/ Creating a Lake #483
What I'm concerned about is the pipe being to small which is causing the scouring at the inlet/outlet. Unless you're trying to restrict the amount of water flowing through it, it may be better to increase the size of it. Of course, it may be a little late in the game now. I understand if you wouldn't want to redo what you have done already. :)
/ Creating a Lake #484
Problem around here is any hole dug in the ground will fill with water. If you are in a dry area the rain will fill the hole faster than it can drain.
We dug our test pit and the rain held off, it came through ok and we have our system in now.
Of course it snowed today and the system is still open waiting for the inspector.
Ken
RobJ said:
I gotta agree, If I dig a perk test hole and it even thinks about filling with water it's time to look for another spot to put the septic. :(
/ Creating a Lake #485
Eddie, that's the weirdest way of pouring concrete i've ever seen !!
Pouring concrete turns a messy job as soon as you mix the water with it, so this is a clean and easy way, without the needs for a form ;)
/ Creating a Lake
Jarrett,
The pipe is 15 inches inside diameter and I can't imagine the amount of rain it would take for it to be undersized. That's just beyond my ability to comprehend based on owning the land for the last 4 years. There is always the possiblity of the hundred and even the five hundred year storm, but if that happens, I don't thinkg a 24 inch pipe would be enough.
The problem is in the amount of water I'm getting, it's in how quickly it's eroding my dirt around the edge of it. Compcting a culvert isn't too complicated on top, but around the edges of the ends takes more effort than I'm capable of. The dirt is only a few months old since it was placed there and hasn't had anything on it to compact it, or anything growing on it to hold it together. I was hopeful that it would work, but that one storm did more damage than I'm willing to live with.
I have a larger 18 inch culvert between that 15 inch one and my open drainaged ditch. It gets three times the runnoff of that 15 inche one, but it has to work it's way around a bunch of trees. I think that slows down the water and it does't do the same level of damage. After that same storm, there is no erosion on that culvert.
In fact, it's pit in front of it is still there with just about no silt sediment, while the one with the damage filled right up on that storm. That may have soemthing to do with it too. Once the pit fills up, the water hits the culvert at full force.
Ken,
I have mostly clay, so if there is a low area, the water will stay for a week or more. I have puddles that are a few inches deep right now that have been holding water for over a week. Evaporation will be my biggest loss of water.
Renze,
I first saw this done several decades ago by both road crews and State Parks. I guess it was before intelocking retaining wall blocks, because that's all I see now. I've seen the stacked concrete sacks run for hundreds of feet and be dozens of feet tall. I dont know what they did behind the sacks of concrete to stabalize it all together, but on a small scale it's pretty simple.
In time, the paper will rot off the sacks and you'll see the cement. Than in time, that will darken and stain to a nice patina that I like. For me, it's a nice rural look that I enjoy.
Eddie
/ Creating a Lake #487
I know where there's a retaining wall like that in Denton. I was really surprised when I first saw it, but I didn't have the camera with me and didn't count the number of sacks, but it's one of the taller retaining walls I've seen.
/ Creating a Lake
We had a 20 minute storm come through last night that dumped an inch and a half or rain according to my rain guage. A quick, heavy storm like that gives me lots of run off, so I was interested to see what the results were like on the culvert.
First picture shows the amount of silt that ended up in the pit before the culvert. It also shows the road over the culvert and the lake.
Second picture shows the amount of water in the lake as of today. I'm stil about 8 feet down, but that means my deepest point is 4 feet deep!!!!
Third picture shows the shallow end of the lake. It will be 8 feet deep there when full.
Fourth picture shows my open drainage to the lake. This is where the bulk of my watershed will come from. It goes along my Western property line and into my neighbors land. From where it turns uphill, it will have a water coming into it from 20 to 40 acres. It's heavliy wooded, so there's no telling how much water I'll get from it. I'm finding that wooded land doesn't shed near as much water as open pasture does. It's not even close what five acres of grass will shed as compared to 20 acres of woods.
Eddie
/ Creating a Lake #489
Hey Eddie. Been waiting on the lake report all day. Being a little north and east from you, we knew you were getting some decent rain. Thought maybe it'd be a little more. Rained hard here most of the night. When we shut our systems down in the middle of the night, it looked like most of the rain was north of you.
Nevertheless, that looks like real progress. I could just imagine you trudging through the mud this morning to check it out. Sure looks different than the first time we saw it.
Mike
/ Creating a Lake
Hey Mike,
Thanks. It's kind of like watching grass grow. Every time it rains, it looks a little different, but just barely. I'm watching the grass grow on the dam too, but that seems to be coming along faster than the water level of the lake. hahaha
Eddie
/ Creating a Lake #491
Wow some of us are pretty close. I am also north of Eddie. I dug a 6ft deep pit about 15ft x 15ft the clay is close to the surface there so only the top foot is sand. The rest and the bottom is thick red clay. After that rain last night, I now have a 15x15ft pond that is 6ft deep. I doubt it will dry out before next year!
/ Creating a Lake
The pump is up and running. I sort of over thought the hole thing and ended up wasting a few hours because of it. In the end, I just tossed the suction tube into the creek and left the pump on the ground. Then I rolled out the discharge hose and realized I'd really messed up. It's way too short.
I don't know what I was thinking, but I only ordered one 50ft hose. That is only long enough to make it almost to the top of the dam. I have a ten foot length of 3 inch grey plasic conduit that I put a fitting on the end.
That just made it ten feet longer and not enough to make a difference. But it was enough for me to slide 60 or so feet of 4 inch corrigated tubing over. The tubing is the cheap stuff, but it will move water and it's big enought that it shouldn't cause me to much restriction.
It's not a tight fit and leaks a little, but that's just something I'll have to live with for a little while. I ordered another 50 foot lenght of 3 inch hose, so when that gets here, I'll do it right. In the mean time, I'll keep messing with it just in case I figure it out.
First picture is of the pump.
Second picture shows the fitting to the pipe.
Third picture shows the pipe to the tubing transition. This is were the leak is.
Fourth picture shows how much water I'm losing from the leak.
Fifth picture shows the tubing as it goes into the lake.
Sixth picture shows the water coming out of the 4 inch corrigated tubing.
Eddie
/ Creating a Lake #494
Eddie, looks like your on your way to a full lake. I just want to share that I just picked up a new 3" X 50' discharge hose at my local RSC rental for 75.99. May be an option for you if you have one close by.
/ Creating a Lake #495
Where's the blazer fuel tank???
There needs to be a poll on how long it will take to fill the lake with a 3" trash pump running 24/7
I say two weeks.
/ Creating a Lake #496
I say two weeks.
I think 2 weeks would put about 5 inches across a 4 acre lake. Thats guessing the flow is about 30gpm which is what that photo looks like to me. Mabey i'm way out on that figure, but even 60gpm is only going to be 10 inches in 2 weeks.
[edit]
(which would put my guess at 3 months :) )
[/edit]
/ Creating a Lake #497
Eddie, I think you could move more volume if you set up the path over the dam as an airtight siphon.
Blue hose is ok for going part way up the hill. But then if you use something the rest of the way up, and going down the lake side, that is rigid enough to not collapse from suction, and airtight, it will 'pull' water up and over so the pump isn't working against so much resistance. Every inch of net lift, without a siphon, is killing the volume you could move. At present you are pushing water clear to the top of the dam. With a siphon you would push it only up to the equivalent of the lake's water level. (in theory)
On the intake side of the pump the lift is even more critical. If you could put that pump on a float it would increase the volume or pressure coming out.
I've used my gold dredge pump, a 5hp 3 x 2 pump similar to yours, to empty a swimming pool. This was driving a 4" venturi (like I described in your pump thread) into 4" corrugated flex for the outlet. The stream coming out the outlet 100 ft away was 4" diameter for 2-3 feet before it began to flatten out.
My buddy said don't worry about erosion, but after the outlet cut a nasty ravine in his lawn he went and bought another 100ft of flex to reach the street. Your rig should erode a hole the size of an oil drum at the outlet, when it is working at capacity.
Your project is fascinating to watch - please keep posting pictures!
/ Creating a Lake #498
Eddie, have you considered a sustainable pumping solution such as solar or wind power? Since you have a stream that you are pulling from maybe even hydropower from the stream?
/ Creating a Lake
Kioti,
Thanks for the source of the hose. When I realized I messed up on the length of hose, I racked my brain trying to think of who would sell 3 inch hose in town. I couldn't come up with anybody, so I ordered another length through Northern Tool. Price with shipping is about the same as what you paid. If I'd been smart, I'd have gone to one of the many rental stores we have. I'm sure one of them would have it.
Wushaw,
The gas tank from the S-10 Blazer is still in the Blazer. I'm thinking this morning would be a good time to pull it out and build a rack to support it. I bought an inline fuel filter to connect the current fuel line on the pump to a line that will lead to the fuel tank, so it should just be a mater of building a rack and sealing off the fuel tank. I'll post pics of how it works out.
Marimus,
The pump is rated for 15,000 gallons an hour. With my leaks right now, I realize I'm not even close to that, but hopefully it will get better when the new hose arrives.
Currently the water from the rains has it around 4 feet deep. That's on the deep end and covers almost half the bottom of the lake. The islands that will be underwater, are all islands, so they are taking up allot of volume right now too.
After running a tank of fuel through the pump, the water level is up over 2 inches. Of course, the higher the water level, the more surface area I have. The math is way beyond what I'm capable off, but it's safe to say I'm making progress.
California,
Your advice makes allot of sense and I can see how it would speed things up. Unfortunatley I've already bought the cheap hoses and feel commited to sticking with using them. They are over $70 each and I don't even want to guess what 100 feet of a stiff hose will cost. hahaha
The goal with the pump is two fold. First, I want to hurry up Mother Nature in filling it up. The ground is saturated now, so I'm getting good runnoff when it rains. There is a good chance that the rains will fill it before Christmas, but just in case, I'm gonna help out as much as possible. On Christmas Eve, we're having the family over here. It would be very, very nice if the lake was full when they get here.
The second reason for the pump is to be able to add water to the lake when it gets real dry and evaporation starts lowering the water level. I don't plan on being able to stop the water level from droping, but I think I can prolong it enough to keep the fish I put in there healthy.
Tim,
Yes, I've been weighing the different methods of pumping water without electricity and may do just that. The problem I run into is there cost to build versus how much water I can get from them. I don't think anything under 100,000 gallons a day will be of any use to me. To my knowledge, that's just not possible without a power supply. I think a Ram Pump would work in my situation, but even a large one will only give me a few thousand gallons a day. In a four acre lake, that's not gonna help very much. I even thought about building a dozen of them, but realize that's just crazy talk. A windmill would also have similar results. We don't get allot of wind here, but might have enough to run a windmill. I priced them out a few times and keep comeing up with more money than I'm comfortable spending for the amount of water I'd be getting.
One day I'll have electricity in that area. I desperately want lights in the trees along the shorline. I'll also put a few electric water pumps in the creek and have them run 24/7. Nat mentioned swimming pool pumps, and there are all sorts of water garden waterfall pumps that are getting more and more energy efficient, so that's another long term idea I have.
If I wasn't so impatient and maybe if we where not having everyone over for Christmas Eve, than I might not be doing this now. Too late now. hahahaha
This is copied from the listing on Ebay and gives the ratings of what the pump is supposed to do.
"This is a brand new in the box 'E.T.Q' brand 6.5 hp, 4 stroke overhead valve Water Pump. It has electronic igination - low oil allert - on & off switch - throttle & choke levers for accurate adjustments - 3" inlet and outlet - with hose fittings and strainer - engine meets new EPA certification - lightweight portable size - easy start and smooth running motor - self priming - Steel wraparound frame - vibration mount - all aluminum die cast pump housing - carbon ceramic mechanical seal - pump lifts to 91.9 feet - suction height 26.3 feet - pump delivery volume 264 g.p.m. - will run continually at full volume for 9 hours on a 3.96 gallon tank of gas - industrial grade pump for use in all weather conditions - large muffler for quite running 69 db - spark plug wrench and manual - makes a great pump for farming, mining, portable water tanks, dredges, marine use, emergency flooding, huricanes - or just a great pump for pumping out the family pool, or whatever you need a industrial pump for. With a one a year warranty."
It fired up on the first pull, it's very quiet and it did self prime itself. For the money, I think it's the best deal around.
Eddie
/ Creating a Lake #500
I've got about 50 hours pumping per inch when the pond is near full and assuming the pump is able to discharge 264 gpm at the head your are using it at.
HARDEE 6' BOX BLADE (A63291)
HARDEE 6' BOX...
2016 CATERPILLAR 416F2 BACKHOE (A63276)
2016 CATERPILLAR...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A60460)
2019 Freightliner...
2014 Ford Transit Connect Passenger Van (A61573)
2014 Ford Transit...
2017 Ford F-250 Ext Cab Pickup Truck (A61573)
2017 Ford F-250...
