Creating a Lake
   / Creating a Lake
Thanks for the advice on the sheepsfoot.
Before I started on this I was looking into either buying one or building one. Problem with pull behind ones is they lack the vibratory motion to work the ground together. Without that added movement, then your just mixing the material a little and adding an additional source of weight for compaction.
My dozer weighs 40,000 pounds, but with the tracks, its psi is quite low. My backhoe weighs 14,000 pounds. With a load of dirt, it's over 16,000 pounds, with the magority of the weight on the front tires. The psi on those small front tires is extremely high.
I spent two days pushing dirt on my key way with the dozer. It feels pretty solid to walk on and after all those passes, I figured I had pretty good compaction. Good enough for what I was trying to do.
Wrong.
One day driving over the same area with the backhoe, and the keyway sunk about four more inches. Now I have the compaction that I need.
No way a pull behind sheepsfoot will give me those same results. The backhoe sheepsfoot roller might do it, but it would be extremely time consuming and I don't have that kind of determination to do the job properly over the entire dike.
I've seen them used on trackhoes for small trench compaction, but usually they use whackers or compact sheepsfoot machines that have the vibratory ability.
   / Creating a Lake #112
Hey Mike, I got into your addition to this thread a little late, but your pond is really nice. It must be gratifying to plan a project like that and see it through to completion with such wonderful results. You have every reason to be proud of creationg such a beautiful place.
One of these days I'll get started on mine . . . /forums/images/graemlins/smile.gif
   / Creating a Lake #113
Jim thanks for the kind words, we did have fun with the project. I was thinking in the back of my mind that you already had a rather large lake on your property, am I wrong here?
I'm hoping Eddie's project for a lake goes smooth as well. I'm really enjoying his pictures and his plan of attack. He looks to me like one of those guys that rolls up his sleeves and gets it done, no matter what stands in his way. Go for it Eddie!
   / Creating a Lake
</font><font color="blue" class="small">( One of these days I'll get started on mine . . . /forums/images/graemlins/smile.gif )</font>
Yeah Jim, whats up with this? I thought you had at least one lake, and from the arial photo's, several lakes at your place?
Mike,
Thanks for the nice words. I am stuborn and will keep pushing until I accomplish what I have to. Not sure if it's a good quality to have or not. /forums/images/graemlins/grin.gif
What I lack in skill and finess, I make up for in determination.
   / Creating a Lake #115
I have a dumb question directed to everyone : Is a keyway and a core trench the same thing?
Also, is the purpose of it to anchor the dam/dyke by digging below grade "x" amount and then building/compacting up from there?
Fantastic job Eddie! You do excellent work with all of your projects. From lamp post's to container barns/apartments to rock entryways....... I enjoy reading all of your posts.
Regards,
Duber
   / Creating a Lake #117
Thanks for that link Mike. I understand much better with pictures. /forums/images/graemlins/grin.gif
Regards,
Duber
   / Creating a Lake #118
)</font>
Yeah, Eddie and Mike, I have two small ponds and share a 20-acre soil conservation lake with three other neighbors. I also have an area that is begging to be put into multiple lakes/ponds due to some serious erosion. In one area, a 50' long dam would flood about 4 acres and that's what I want to do. These will be the first lakes I've been responsible for building on the property. Eddie, you'll see exactly what I'm talking about when you come up for the get-together. /forums/images/graemlins/cool.gif
...but here's a picture of the area from the air in the right and upper right (attached). Right now this is my "ATV/UTV fun course."
   / Creating a Lake
It's been awhile since I've been to the dike. Another project came up that needs to get done in less then two weeks.
It rained the other day and this morning my girlfriend, her kids and I went for a walk. These tracks are about as fresh as they come without actually seeing them being made.
2844 (A58376)
2844 (A58376)
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
Bush Hog 3pt 14' Mower (A53317)
Bush Hog 3pt 14'...
Chevrolet 2500 Flat bed (A56438)
Chevrolet 2500...
Acura-Trak Hyd. 3Pt Quick Hitch (A59814)
Acura-Trak Hyd...
