Oh Richard- Here we go with the attitude here. Why not think before you type a post. Now I will have to hit the wonferful mod button.
</font><font color="blue" class="small">( If you'd read the posts instead of always trying to be argumentative then you'd know that I said we use it so we don't have to buy winter diesel blend. Chances are if you buy winter blend fuel you'll be fine. But it only takes one time of being gelled on the side of the road and having to be towed to spend a couple cents to put it in a tank of fuel. )</font>
Chances are???? After 9+ years with no problems, I think chances are out. I had my truck for over 4 years and had zero gelling. Again, as I have posted before it was a waste, WASTE, for me in my area.
</font><font color="blue" class="small">( If you're storing fuel for a period of time personally I think you're playing with fire if you don't add some kind of microbial agent and water dispersing agent to it. )</font>
That is weird since I have only had diesel tractors like 6 years without a problem. I know many farmers up here that do nothing and fuel is fine….hmmm weird.
</font><font color="blue" class="small">( As far as Ford not recommending it that's because they recommend stanadyne. They also don't recommend synthetic oil but you think that's ok. They don't recommend extended drains either but you think that's ok. Speaking out of both sides of your mouth here aren't you? )</font>
Hmm, in the manual it states what I posted. They do recommend synthetic oil like anyother car maker. The problem with most makers is if you open the door to extended drains every moron out there will jump on board. As I have stated a long time ago, most users can’t even add oil to there car. Now you are going to tell them they can go longer, ya right. 80% of the public thinks the 3K drains is a must. Then the price is involved. Most will not pay the $$$ for the oil when the cheap dino stuff is 80% less.
</font><font color="blue" class="small">( For diesels that rely on the diesel fuel for lubrication some kind of lubricating additive is critical for low sulfur fuels. )</font>
the low sulfer fuels have been around for years cowboy. Nothing new here and the lube issue is getting about 10 years old….
</font><font color="blue" class="small">( If you're adding 96 ounces of powerservice to a fillup then you're not very smart. 96 ounces will treat 300 gallons. Powerservice here sells for $6.99. That equates to 2 cents per gallon to use powerservice. For 2 cents per gallon I'll take all the benefits of using it. )</font>
I never stated 96 oz at fill up. All I stated was ,” PowesService at 96 oz for like $11?” I did not say I added it all at one time. Never assume thing cowboy..bad bad
</font><font color="blue" class="small">( Someone like you that lives in town and only has a BX diesel to run and probably buys it in five gallon drums it probably isn't an absolute necessity. You are going to get the winter diesel only and won't have a choice to get pure diesel. )</font>
I live in a city. Not a town my friend. In this area after like October you can’t buy summer fuel..
</font><font color="blue" class="small">( You also have a newer diesel that isn't as dependent on the fuel lubrication. )</font>
Did not the low sulfer fuel come out like 10+ years ago….
</font><font color="blue" class="small">( You will also probably never run your diesel long enough for soot or dirty injectors to be an issue. In your case no it's probably not worth it to you. )</font>
Gee, what have I been stated..I said it was a waste…..
</font><font color="blue" class="small">( In situations where guys use their tractor or vehicle more, have fuel delivered and it sits awhile, want to improve your cetane #'s, want the cleaning and oxidation properties, want the soot control, etc. then it's extremely beneficial. )</font>
My bx sits a lot, but fuel is fine. My last tractor was also fine. Soot control is not important unless it is in your oil. At least I could carless about emissions on my BX or any truck. The state mandates the soot control on emission. If I do not need it. I do not bother.
</font><font color="blue" class="small">( Your case it's not. Different situation different needs. It works for us and in your case it didn't work for you.)</font>
See two answers back..nothing new .
