Different Pole Barn system?
/ Different Pole Barn system? #1
Wesdor
Western Illinois
JD 3720
I'm looking to build a pole barn type structure in the spring and ran across the Socet System. Just wondering if there is anyone out there that has experience with this company. Any constructive comments would be appreciated.
From the looks of their website, a person can build a barn that has more space and is no more expensive.
Sometimes, if things look too good to be true that turns out to be a problem.
web page
/ Different Pole Barn system? #2
Hey thanks for the web site, I think its a VERY interesting approach. I've emailed the company for further info, eg local engineering, snow loads, wind shear, etc. I'm looking to build a new shop for myself and this has some definate advantages. I'll post what I find out.
/ Different Pole Barn system? #3
Just looked over the web page. Looks like a nice way to go. The raisings look fun with a tractor and/or winch. I like the fact that the poles are out of the ground as well....makes for a more permanent building. They show some huge buidings, but smaller ones look pretty easy to set up. I like it. Maybe someone will have experience or have some comments that've used this or something similar.
/ Different Pole Barn system? #5
Thanks for the link.
/ Different Pole Barn system? #6
I'm currently building a 28' x 28' barn using socket system parts. I'll post pictures tonight when I get back home. The obvious advantages are the ability to erect the structure without any heavy equipment and having a clear span - no poles in the middle. My father and I are putting mine together. I hope to have it roofed before the end of the month.
Ken in Tennessee
/ Different Pole Barn system? #7
the following is a series of pictures of the construction of my barn using the "socket system". It is 28'x28'. The vertical sides are 14' and the roof slope is 7/12.
Link one has the first steps...layout of the perimeter, digging the holes for the corners...
Barn page 1
link two is the raising of the frames
Barn Page 2
link 3 is the completed frames and the beginning of the roof
Barn Page 3
I'll post more as things progress
Thanks for the pictures!
This is what I was hoping for. From the information I have received from socket systems, I thought I would need 5' centers, but yours looks much further apart. What do figure is your snow load (I didn't check where you are located).
Also, how would you compare the cost to a normal truss type building?
Thanks again for the excellent pictures. Please keep the coming.
/ Different Pole Barn system? #9
somewhere on their website they have information on differing spans for differing snowloads. I live in SE Tennessee... we're lucky to get a light dusting of snow once per year. My span is 14' using 8" purlins. I will eventually have a 2nd floor loft which will also tie things together much better.
/ Different Pole Barn system? #10
kwTN,
I'm very interested in your barn project. How did you know what you needed from Socket Systems? Did they provide a 28'x28' plan/package that you bought? Or, did you have to figure out all the parts you needed from them? I might go this route when I (finally) get around to building my barn, and wondered how difficult it was sorting out the supply list.
28'x28' will be a nice size. I was thinking something more along the lines of 20'x24' or maybe 24'x28' for mine. Any information you can provide would be appreciated, and please keep posting the pictures of the progress.
Thanks,
Robert Aldridge
/ Different Pole Barn system? #11
Are the post anchor bolts long? How far below the forms do the sit in the column? I looks like the steel anchor plate sits on the edge of the column, and would crack out easily. Maybe I am looking at it wrong.
I'm also curious how this system compares pricewise to the standard pole and truss designs. Do you know how much more or less this will cost you? Did you use SPF or Yellow Pine for the frames?
Thanks
/ Different Pole Barn system? #12
getting the right parts is easy. once you've decided on your bay width, span, and roof style, Rodger at SocketSystems can develop your component list. I told him I needed the components for 3 gable frames at a 28' span using roof purlins. I received all the socket connectors, bolts, screws and purlin clips needed. they supply generic instructions that are easy enough to follow.
My barn is a bit taller than I had originally envisioned - about 26' from ground to peak. Kind of makes it tough hauling 15' long 2x8's to the top to install the purlins
/ Different Pole Barn system? #13
the base sockets are roughly in the middle of the concrete support - 12" round hole x 3' deep. what is visible on top of the ground is a 6" high 10" square. the bases have 2 j-bolts embedded in the concrete - I think they are around 12" long
I'm using standard pine lumber.
I think price wise it will be about the same as poles and trusses. However, I could pickup all the materials myself - it is a long way out to where I'm building and timing/cost of delivery would be a pain.
/ Different Pole Barn system? #14
Thanks for the pix and info, I'm planning on doing a building first part of next year. Keep the info coming.
/ Different Pole Barn system? #15
Hey Synchro -
I saw the snow load calculations on the website, but I am more interested in wind sheer/load ratings. Have you received any feedback from company yet?
/ Different Pole Barn system? #16
<font color="blue">I saw the snow load calculations on the website, but I am more interested in wind sheer/load ratings. Have you received any feedback from company yet? </font>
Yes I got an email from them directing me to the web site load engineering page, but that was it. I kinda think a local engineer would be needed if wind shear is an issue where you live, as it is in my area.
I don't know yet what I'm gonna do, I may just go steel for the shop. What drew me to this type of structure was it could have a lower profile and still have a 14' high end roll-up door, plus it doesn't look 'commercial' as most steel buildings do. I'm also playing with some house designs, but not seriously persuing anything just yet. It has appeal. so If and when I decide to do a project using the system I'll post it here.
/ Different Pole Barn system? #18
I was interested in this as I wish to build a garage with an apartment above it and this looks like it would do the trick. But I have one dumb question what would be the easiest way to insultate the roof. I have seen section roofing system where you place it on rafters I believe and it has the sheet rock and insultation right in the modular. Then I think you can do a shingle roof to the outside? Does anybody have an idea of what I am talking about? If so do have the web page
Thank you Michelle
/ Different Pole Barn system? #19
</font><font color="blue" class="small">( I was interested in this as I wish to build a garage with an apartment above it and this looks like it would do the trick. But I have one dumb question what would be the easiest way to insultate the roof. I have seen section roofing system where you place it on rafters I believe and it has the sheet rock and insultation right in the modular. Then I think you can do a shingle roof to the outside? Does anybody have an idea of what I am talking about? If so do have the web page
Thank you Michelle )</font>Do a search on "structural insulated panels". You will find enough web sites to keep you busy for the rest of the evening and then some.
/ Different Pole Barn system? #20
Interesting, but the components seem to be a little pricy.
Also, the "engineering package" that comes with the parts may not be enough to get you a building permit. You may need more engineering calculations for the specific structure you're building. Figure on spending another $500-1000 if your county building department makes you get more engineering.
(INOP) JOHN DEERE 450CE CRAWLER DOZER (A59823)
(INOP) JOHN DEERE...
2012 PETERBILT 386 6X4 T/A SLEEPER TRUCK TRACTOR (A59906)
2012 PETERBILT 386...
(INOP) 2012 INTERNATIONAL DURASTAR 4300 SBA TRUCK (A59823)
(INOP) 2012...
2021 SANY SY365C9C5K (A58214)
2021 SANY...
1998 INTERNATIONAL 9400 (A58214)
1998 INTERNATIONAL...
Mahindra 5145 (A60462)
