Digging Shale: Ripper (frost tooth) or rock teeth?
   / Digging Shale: Ripper (frost tooth) or rock teeth? #1
RedNeckRacin
Elite Member
Western PA
John Deere 5083E MFWD, Kubota L3400 HST
So I have a question that I'm not sure where it fits into but this was my best guess.
Backstory: Anyways, I have a shallow layer of topsoil then clay then increasingly harder shale the deeper you go. I have a building on a level pad that was cut into the hillside. I can put water lines and a drainage line in deep enough until about the middle of the pad where I run into the shale at depth. This has not been a big problem and I usually just worked around it. SO the problem comes into play with the possibility of putting a "lean-to" on the upslope side for convenient hay storage. (Yes the out slope would be easier but there are other plans for it. The contractor who installed the building had a heck of a time drilling the holes for the posts.
I was interested in tackling a project and gaining some more space for the addition. I know I basically have three options. My granddad owns a 480C back hoe which I pretty much have unlimited use of as long as I fix it when it breaks (which happens somewhat regularly due to age.) I can rent a small bobcat (about a 331) that will dig circles around the older case but I have to pay to rent it. Or I can contract it out( hopefully this is a last resort but remains a viable option) but the least desirable at this time.
My first thought was to build/buy a ripper (frost tooth) to replace the bucket on either machine and have at it. There are some cheaper used buckets on the classifieds and eBay that I could use the mounting flange and add on from there. The rental place has no problem with changing attachments as long as it was made for that machine.
My next thought was why bother with all that fabrication when they already make rock teeth for both machine's buckets and relatively cheaply compared to fabricating/buying a specialty tool.
I guess my question would be, is it worth buying the rock teeth for the case or the bobcat, or should I just get down to fabricating something for my needs?
Note: I have tried the narrowest buckets on both machines already and it´s almost a fruitless process to make any advances. It´s also not feasible to run anything up and down the slope due to the proximity of the building to the toe of the slope. SO I basically have access to three sides of it. The other thing is that the building is 100' long and I would like to blend the current slope into the proposed one.
Anybody have any good ideas? Searching hasn't provided much help either.
   / Digging Shale: Ripper (frost tooth) or rock teeth? #2
Best check out a Cat with a proper ripper and a u blade. It'll work.:thumbsup:
Do you have one I can borrow? :D
   / Digging Shale: Ripper (frost tooth) or rock teeth? #4
How about a machine equipped with an air or hydraulic chisel/hammer? No, I don't have one :laughing: but they seem to be useful in rocky construction sites. It might break up the shale enough to make it dig-able with the 480C backhoe bucket.
   / Digging Shale: Ripper (frost tooth) or rock teeth? #6
A bobcat with a pavement breaker,(hydraulic hammer) would be what I would get. Make the ditch line with your backhoe to the rock base then run the pavement breaker breaking the rock about every foot and then scoop it out with your back hoe. Repeat as necessary for the necessary depth. The pavement breaker is going to only have about 12" of penetration, so it may take a couple passes.
   / Digging Shale: Ripper (frost tooth) or rock teeth? #7
Is the backhoe is reasonably sound with good beakout force use a single tyne ripper on the backhoe, then scoop out with the FEL.
The viability all depends on the size of your excavation & how many cubic yards you'll be moving, the "challenges" of old backhoe might just be outweighed by the ease & speed of renting/operating a c.7-12T Excavator with ripper/buckets.
And what are your intentions for the excavated material ? If you need to move a large volume any distance you may be better off using a contractor complete with excavator & truck - consider also compacted shale makes for a pretty good road ( in which case a contractor with a traxcavator is the better machine choice.....)
   / Digging Shale: Ripper (frost tooth) or rock teeth? #8
I worked a job in York Pa that had a rock that was not real hard and not real soft. The breaker did not work well because the rock was to soft and an excavator that was big enough that 3 buckets over loaded a quad dump could not pull a frost tooth through it because it was to hard. We did the plumbing and many days we put in 20 to 40 ft of pipe because the hoes were so slow. Try the backhoe and move up if needed. That way you get done what you can for as cheep as you can, before you spend extra cash on something else, if you need to.
The backhoe runs pretty good actually, just has some bad hoses that leak some fluid. Very good on fuel too. I'm actually pretty handy with the old 3 stick controls (4 with the extend-a-hoe) and I am actually competent enough to be able to drive with one hand and row myself along with the hoe in the other hand when the 2wd isn't enough.
Gary-There are alot of shale pits in the area that farmers and contractors use for road building material in the area so I think the hammer might be a bit extreme/not practical? Thats why I was thinking of changing out the spade teeth for the tiger teeth that narrow down to a single point increasing the psi and hopefully the penetration of the bucket to maybe avoid a frost tooth. I was cosidering the ripper idea because I enjoy fabricating items for my own use. (cheapest option first) I'm also not putting in a simple ditch (atleast not at first) I need to excavate about 100' long by about 25' wide and approximately 6' deep and gradually increasing. Might also feather in the ends per say.
The mini hoe was the next closest/cheapest machine that I have had success with in the past until I got into the tighter shale. There is a equipment dealer not to far away that has some bigger equipment but bigger equipment means more money and I'd rather not try and kill myself getting my money's worth over a weekend.
MBTRAC
-I didn't really have any plans for the material other than maybe filling in a gully that has a spring in the bottom of it. I could actually stockpile it off to the side or dump it out over the side of the parking lot and expand that some. Its going to be a large pile of material thats for sure! somewhere around 600 yards? I'm not in a really big hurry so I do have some time to ponder things. I'm pretty sure that a contractor is going to be the most cost effective option, BUT I'm letting my mind run a little bit to see what I would be in for.
   / Digging Shale: Ripper (frost tooth) or rock teeth? #10
What about a kamatsu dozer with one of those big a ss rock hooks on the back?
   / Digging Shale: Ripper (frost tooth) or rock teeth? #11
I would try the frost tooth on the backhoe. A breaker will not work because it is too soft as noted, it will just punch holes. Also your best bet is to do it when it is wet out. When dry, shale becomes much harder. We have a post driver with a pilot auger that will drill through light rock. In the dry summer I have hit shale that took almost half an hour of drilling to make a 5" by 42" deep pilot hole. The farm we used to live at had horrible shale and fencing and trenching were a constant nightmare, glad we don't have to deal with it anymore.
Well I'm trying to use my available equipment first. I may have to break down and rent a machine. I do have access to an older John deere 450B track loader. It does not have rippers on it though.
I'm thinking the tiger rock teeth on the backhoe is going to be my first and best bet. (money wise) I can sit on top of the bank and pull the shale up towards my machine and should dig pretty easily that way. If that doesn't do it, it sort of throws the little mini hoe out the window since they have comparable breakout forces.
   / Digging Shale: Ripper (frost tooth) or rock teeth? #13
Maybe I misunderstood you, but I thought you said that the back hoe wouldn't dig it out. I have dug out shale here with my little B26 but it is rough on the backhoe but it does break up into small pieces. I just have regular teeth on mine but it digs slowly till it hits hard spots. It is hard enough to break with a pavement breaker also. I would think that if you have teeth on your bucket it would break it up if it is the same thing I have. A pavement breaker would make it so much easier though by busting it up first.
Gary,
I tried putting in a water line that is below the grade of what I am planning on excavating. Granted I'm moving up the hill so I may or may not encounter the same conditions. If I put better teeth on the bucket it should increase my digging force considerably. If that wasn't worth the effort, I was planning on building a frost tooth (ripper) and having at it.
UNUSED FUTURE 13C EXCAVATOR (A60430)
UNUSED FUTURE 13C...
2010 Doyle 32ft Tender Trailer - Kubota Diesel - Stainless Steel Augers - Recently Refurbished (A61307)
2010 Doyle 32ft...
John Deere 6120M (A57148)
John Deere 6120M...
Redirective Crash Cushion Guardrail (A59230)
Redirective Crash...
2019 Caterpillar 259D Compact Track Loader Skid Steer (A59228)
2019 Caterpillar...
JOHN DEERE 26G EXCAVATOR (A60429)
JOHN DEERE 26G...
