Disking up food plots
   / Disking up food plots #11
</font><font color="blue" class="small">( Wouldn't the lime & fertilizer burn the seedlings if it's not worked in? )</font>
Ideally, I do try to either lightly disc or drag the plot after fertilizing and before seeding to mix the fertilizer in. However, ideal conditions are very infrequent. With limited time to get plots planted and rain on the way, I'll fertilize and seed and then lightly drag the plot (don't cover the seed too deep or your germination rate will be terrible). Seeds that are in direct contact with fertilizer pellets will likely "burn up." This should be a very small percentage of the seed. And, if you get a rain fairly quickly to dissolve the fertilizer, you should have a pretty good germination rate and the fertilizer readily available to the new roots.
BR
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
1995 Stoughton Enclosed Dry Van Trailer, VIN # 1DW1A5323SS900663 (A57453)
1995 Stoughton...
167 (A52708)
167 (A52708)
Adams Tilt Trailer (A56436)
Adams Tilt Trailer...
2019 CATERPILLAR  XQ35 GENERATOR (A58214)
2019 CATERPILLAR...
