Dunham Cultipacker
/ Dunham Cultipacker #1
L3650
Recently I rescued two sections of a larger cultipacker being scrapped out. All the tempered angle and channel from the hitch had already been torched off but I managed to save the roller assemblies.
One of the bearing housings was just wore out, literally gone. Any way, when taking apart to rebuild, the bearing housing is octogon shaped with wood splines supporting the shaft. Does anyone know where parts for this vintage equipment is available?
/ Dunham Cultipacker #2
Ken Sweet at sweettractors.com would know.
Sweet Tractors is an advertiser here on TBN, located in Kentucky.
Sweet specializes in used and rebuilt implements and usually has Dunham brand Cultipackers for sale.
Sweet likely has a stock of salvage parts for your Dunham.
OPEN LINK:
Used Dunham 6 Ft Cultipacker-Pulverizer, Bearings.Store.Pickup
/ Dunham Cultipacker #3
I rebuilt a old dunham a couple years ago. I just used a hole saw kit and a table saw to make new wood bushings. I used a piece of oak from the wood pile, but if possible I would use osage orange if availiable.
/ Dunham Cultipacker #5
I have a Dunham cultipacker that looks just like the one you show here....it has the "sprocket" wheels alternating with the smooth packer wheels. I've never taken mine apart - I've just greased the zerks really well and pulled it about.
The main shaft that holds the wheels doesnt rotate too much....as the wheels are not very tight on the shaft and rotate independently from the main shaft. Is the housing that holds the bearing erroded away?? If so, finding an end housing may be pretty tough. Id consider replacing the Dunham housing with a new pillow block bearing - if I were in your shoes.
iDrive TDS-2010H...
2018 Trail King Lowboy (A63689)
2018 Trail King...
2017 NISSAN NV2500 4x2 VAN (A59911)
2017 NISSAN NV2500...
2023 Case TV620B (A64119)
2023 Case TV620B...
1991 25ft Wellcraft 250 Sportsman Boat with 2008 T/A Boat Trailer. (A61574)
1991 25ft...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
