Everlast welders, anybody own one?
   / Everlast welders, anybody own one? #31
I've got ball caps for almost all the equipment, toys and tools I own, and never wore ANY of them... Well, except maybe Perazzi that I used to wear from time to time. I make a poor rolling advertisement! LOL
Ironnut,
I am not sure if your date is reflecting correctly, but the FIRST post was in 2010, and the last one in the sticky, just a few days ago. We post when we have something to update or announce, not just for banter. I comment almost daily here though in other threads. We ARE and HAVE been active contributors and supporters of this forum, for a while now. Please let us know how we can help you.
Gumshu,
IF you want the 300 we can make it happen. Forget about amazon, because you don't get a discount there for tbn. But you're going to need to double the size of that 30 amp breaker you were talking about yesterday. You'll need to go to that heavier gauge then. Same as with the 250stickweld from our competitor...I can promise you the 300 won't disappoint against anyone's machine...our competitor here included.
Mark,
Well I guess I screwed up. I used Amazon last Saturday to purchase the PowerTig 250ex. Supposedly it is to ship today as we have a UPS tracking number.
gordon
   / Everlast welders, anybody own one? #33
Every customer would get a ball cap if I had any.
   / Everlast welders, anybody own one? #34
Mark,
gordon
Hey Gordon, you can always cancel that order with Amazon (like I've done before) and place it through Mark. Mark had my machine on the way as soon as I hung up the phone... with an email confirmation and ups tracking number. Like I said, he's "Johny on the spot." You can't beat a direct sale.
   / Everlast welders, anybody own one? #35
Honestly, I have dropped the ball once in a while...but I do try to give the best service I can personally. Had a guy call me I sold one from 2010 yesterday afternoon.
Re: Everlast welders, anybody own one? I do now.
Some would consider this a dead thread, I suggest that it was just aestivating through the long hot summer.
I bought an Everlast 250ex a couple months ago. It works as advertised. More welding machine than the welder using it. The Everlast 250ex is an inverter welder. Inverter welders definitely have a different output than transformer machines. I think different in this case is better. The Everlast machine replaces/augments my Miller Thunderbolt AC/DC machine. I think my 6010 welding is better with the Everlast than it was with the Thunderbolt, though, even with the ARC force adjustment turned to max I still experience loss of the arc (but restarting is fairly easy). DC tig works well and I can make some nice looking welds in steel. AC tig on Aluminum is not consistent though not the fault of the welding machine. Sometimes I can make a "stack of dimes" other times, chicken scratching. I am not a welding professional, though I have used a number of machines over the years (Miller, Lincoln, Linde, P&H, Forney, home grown). Prior to adding the Everlast, I had the Miller Thunderbolt and a Lincoln SP-180T mig welder. I nearly bought the Hobart version of the Miller Diversion machine (~$1600). The 250ex was ~$1600 for a 250 amp machine and a lot of control knobs plus stick welding capability while the Miller Diversion is ~180 amp and a very simple set of controls, but no stick welding.
I searched the Internet and read through some of the "horror" stories of this brand vs another brand. The video on welding TipsAndTricks.com where Jody demonstrates how to set up the Everlast 250ex was a deciding factor for my purchase. You can access the videos via the Everlast web site Welding Tips & Tricks Reviews the Everlast 250 EX . I would not recommend trying to purchase the Everlast 250ext model as it has been a source of a few horror stories. To Everlast's credit the thread is available for all to read (under TIG welding, ***250EXT***). Assuming that you intend to also do stick welding, make sure that the welding machine you purchase has the arc force control. It is pretty much required on an inverter machine if you intend to run 6010. Also make sure your auto darkening helmet is rated for TIG welding. Not all auto darkening helmets work well when doing DC TIG. Apparently the sensors in the welding helmet are dependent on the rate change or lack of rate change in the light intensity to trigger and hold darkened and un-darkened modes respectively. Inverter machines have very stable DC TIG arcs which can fool some helmets into reverting to the un-darkened mode.
Aside from a few niggling issues, i.e. the supplied stick welding leads could stand be a few feet longer, and some confusion as to how to connect the 220volt single phase power, I am satisfied with my purchase. As to power input requirements Everlast recommends a 50amp 220 single phase circuit. The 250ex can also be connected to a 3 phase source, which was part of the confusion. One of things touted for an Inverter based welder is higher efficiency. This appears to be true as I have been running on a 30 amp 220 single phase circuit. Yesterday I burnt up a dozen 1/8th inch 6010 rods fixing the brush cutter hitch. I was running at a 100 welding amps pretty much continuously. No breaker tripping.
As always your mileage may vary. Good luck to any in their search for an affordable welding machine.
gordon
   / Everlast welders, anybody own one? #37
A few notes...The EX isn't designed specifically for 6010, so if you are welding with it, good, but we don't promote it to weld 6010 or promise that it will anywhere I can think of in our literature. Arc force control doesn't make one weld 6010...Higher voltage output does. It'll run 6011 fine.
The confusion of wiring the welder shouldn't be anymore than any dual phase welder as we use the standard wire colors, and it is very plainly described in the manual available for all to see online.
The 250EXT has had an issue with starting, but there are only a limited number of machines out there, and we are not selling more until the issue is resolved. However, the 210EXT is a totally different animal, and have had great success already with them.
   / Everlast welders, anybody own one? #38
I am no expert by any stretch of the imagination, but what I have found with my Lincoln V350-Pro is turn the arc force to 0.0 when welding with 6010. This gives me the stack of dimes look with out even trying. For open root pipe welding, and vertical up with 7018 I run the arc force at +9.5.
Here is a 6010 weld I made when I first got my Everlast PA-200.
   / Everlast welders, anybody own one? #39
:laughing::laughing::laughing:......"No expert" - right.....:laughing::laughing::laughing::laughing:
   / Everlast welders, anybody own one? #40
I'm not! But I generally can stick things together.:yes:
UNUSED FUTURE SKID STEER QUICK ATTACH BACKHOE ARM (A51244)
UNUSED FUTURE SKID...
2016 FORD F-250 SUPER DUTY SERVICE TRUCK (A51243)
2016 FORD F-250...
2017 Nissan Pathfinder SUV (A50324)
2017 Nissan...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
UNUSED CFG Industrial MX50R Mini Excavator (A47384)
UNUSED CFG...
2015 KOMATSU PC170LC-10 EXCAVATOR (A50458)
2015 KOMATSU...
