Farmi 501 Logging Winch & Snatch Block
   / Farmi 501 Logging Winch & Snatch Block #1
AndyMA
Elite Member
Windham County, Conn
Ford 2120 , Kubota MX5200 , Deere X748SE. 1956 Economy Tractor
Just thought I'd post a few pictures of our Farmi 501 winch in action. It is mounted on a Ford / NH 2120. We are only pulling one or 2 large oaks at a time since my son Jim was doing the pulling. Normally I would be pulling 6-8 of the tree size shown. The Farmi winch pulls at over 11,000 # and has 165 feet of cable. The blade digs in well to hold the tractor and also is used as a plow to fill in ruts and move snow.
Note the plastic chain saw bar guard that slips into the slot on either side of the winch to carry a chain saw.
Farmi Winches
Andy
Another pic
another
This attachment is the self releasing snatch block from Farmi. It allows you to pull at an angle toward a tree and then when the chain hook hits the snatch block it "falls" off and the log changes direction toward the tractor. Very useful as many times you can't get a straight pull toward the tractor.
Andy
   / Farmi 501 Logging Winch & Snatch Block #5
Andy,
I've got the same tractor/loader/winch setup as you. The only thing I lack is a son to help, I bet that's the handiest attachment of all. I've worked it pretty hard this winter, and I'm finding the cable is getting some bends in it from the way it rolls up and crosses itself. Except for a little winch on the front of my four wheeler this is my first so I'm not sure if that is normal or should I be pulling the cable out and rewinding under load more often to avoid this? It sure is a handy tool and I still plan on mounting a hitch to it when the weather warms up a little.
   / Farmi 501 Logging Winch & Snatch Block #6
Hey AndyMa,
It looks great, how much was it.
I need one of them.
   / Farmi 501 Logging Winch & Snatch Block #7
You've got it... rewind under a load often to avoid kinking the cable.
Don't go near it with a full regular load on, if it snaps, it will not be pretty... As with any pulling, hoisting, or winching, Be Safe so you can come to the forum and tell us about your latest tractor adventure.
I think the 501 was about $3200. I'm not sure because I had a 351 and traded it for the 501.
Andy
2016 PETERBILT PB337 FLATBED TRUCK (A52706)
2016 PETERBILT...
2025 GPS Equipment Trailer (A56859)
2025 GPS Equipment...
DEUTZ MARATHON 60KW GENERATOR (A58214)
DEUTZ MARATHON...
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
2014 Chevrolet Impala Sedan (A59231)
2014 Chevrolet...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
