Got to use the tractor for the first time today. Some good news, not so good news, and some observations.
I maintain our 1/2 mile dirt road. Had lots of pot holes and wash board. I've been using a landscape drag which is basically a few pieces of angle iron welded into a diamond shape with a drawbar welded on. I had about 250lbs of block on it for ballast. It pulled fine on the level portions of the road, but if I had any kind of dirt in the landscape drag and was going uphill I had traction problems. One of the tires has calcium in it, the other does not. Finding weights for these rims is near impossible because they are of a three bolt mount design.
Second issue was with the steering. With dirt in the drag I noticed the front end would get light. When I would turn around at the end of the road the tires would slide and the tractor would continue to go straight. I had three suitcase weights on the front. When I got back to the shop I added the two other weights to try and help this situation.
When attaching the weights I noticed oil on the front axle. Closer inspection revealed a front main seal leak...bummer. My Brother said to loosen the fan belt a little. He has seen that work in the past on cars.
Last issue was the electrical system. With the engine running and lights off the voltage sits at 13.8v but when I turn on the lights the voltage drops to slightly below 12v. I suspect a faulty voltage regulator. When I took it apart for cleaning there was some corrosion in there. Thinking something is roached inside.
Good news is the engine runs great, three point and quick hitch work awesome, water pump doesn't leak, and clutch seems to work fine.
Overall I'm happy with the tractor, just some bugs to work out.
