Ford 5000, Kelley front end loader 800 model
   / Ford 5000, Kelley front end loader 800 model
Ok guys, I put the new hose on the loader, started it up, let it run, and nothing, the loader won't budge. Do I have to bleed this system some how, and how do I do this. also, where do you add hydraulic fluid I hae type 134 from the ford dealer. "But i do not know where to put it in, or how much. Any help.
PS, the 3 point point hitch wasn't working, but now it is. what did i do, I didn't touch nothing else.
If you are saying that your tractor system is closed center hyd, that changes things. The valves added will have to be closed center valves and can be connected in parallel.
Hey JJ, I put on the new line. and I have no power to the loader, any suggestions? Also, where do i add fluid lost during the break, and how much.
   / Ford 5000, Kelley front end loader 800 model #23
Do you have a hyd gage? Tell us where you have pressure. If your pump is turning, you should have some flow, and if the loader valve is good, then the cyl should work.
Find the reservoir/tank and top off the fluid. Pump has to have fluid to pump.
Rudolph bros, nathen says I got the tractor in the picture and it does not matter that he made a mistake on the year. But he don't think he did. he says you go by the serial number C159450. He says the 1 is really a 4, which means its a 1976. The local New Holland/Ford dealer says you go by the Product Code numbers 6M13 meaning 1966, Dec 13th. I found it on Tractor House.com Listed as a 1976 Ford 5000.
So this is where I am at with it. He will not take it back, he will not do anything, The tractor I got, is the one I saw a picture of, and thats all the matters.
Thanks JJ, where would the resovoir tank be, there is not one on the loader, its hooked directly in to the rear end houseing , one hose in front of the seat, and once on the left side rear. about half way down. There appears to be a filler cap on the right side just behind the seat, but I don't know how full to fill it. Any suggestions, surely not to overflowing.
The loader arms raised and lowered the bucket, before I put on the new hose, but it was the line to the bucket that had blown. Its now replaced with a new hose. Neither the loader will lift, nor will the bucket move. Could it be air locked or something.
Thru the filler cap, on the right corner rear of the seat, it looks about half full to half empty. A little joke. I added two quarts and still nothing.
   / Ford 5000, Kelley front end loader 800 model #28
rear sump is the hyds sump.. there should be a big pipe plug there to check level.. on the back, left side...
might have to refill after bleeding the hyds.
it's the date code AND the model ID.. ealy units model id 5.. late units D
soundguy
   / Ford 5000, Kelley front end loader 800 model #29
2qts in a sump that can hold 13g ain't much.. depending on how low it was.
did you ange any of the controls on the diverter or your loader control, or remote?
soundguy
Thanks Sound guy. That plug is where they put the returen hyd hose. I removed the hose, and it didn't run out there, So i will add more fluid. Thanks.
But if the system needs bleeding, I don't know how to do that, I know how to bleed brakes on a car. I guess i will have to find someone to do that for me. Just another cost of being a tractor owner.
2008 MACK CHU613 DAYCAB (INOPERABLE) (A58214)
2008 MACK CHU613...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A59228)
2006 iDrive...
LIMA MAC 30KW GENERATOR (A58214)
LIMA MAC 30KW...
Compressor (A55973)
Compressor (A55973)
Kubota BX25D (A53317)
