Help! DIY board fence installation. When/How to trim posts.
   / Help! DIY board fence installation. When/How to trim posts. #11
I agree with the others, put the boards up, then whack the tops off with the chainsaw. A good sharp saw will cut each top in just a few seconds.
   / Help! DIY board fence installation. When/How to trim posts. #12
you could mark the piece and then take the top rail down that way you would not cut into it. Not sure if its a problem but on our 3 rail, I used 4x4 for the posts and had to put a rain cap on top otherwise the post was rotting out.
   / Help! DIY board fence installation. When/How to trim posts. #13
All good replies...
I will only add(after doing 6 acres - various paddocks) make a story board pole. Take a piece of wood and mark your rail heights on it. Put it next to each post and mark a reference point on the post. Essentially your are marking the elevation of the terrain. You can than decide to either cut the post off before attaching the top rail or attach top rail and cut. The wood block gauge on the top rail will give an overall even appearance. You can slant the post top using a chainsaw or for a finer cut a recip saw with a good wood blade. One other approach, from an old timer - is to find an appropriate tin can(cat or dog food or soup) and cut it down to 2-3 inches depending on your space and cap each post. He has done this for years and all of the posts(we share a fence-line) are sound - 20+ years.
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
2022 John Deere 1025R (A53317)
2022 John Deere...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
1979 Ford F-100 Ranger Pickup Truck (A59230)
1979 Ford F-100...
2013 Ram 3500 Flatbed Truck (A59814)
2013 Ram 3500...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
