How tight are your chains?
   / How tight are your chains? #71
whistlepig shows some real heavy duty tensioners, nothing would come loose with those on, maybe tough to get them on at first.
JB
They are heavy duty tensioners (got a set) and there is a binder tool (which I have...now) available to install those tensioners.
One thing shown in whistlepig's picture is the hooks that tie the tensioner into the chain are in the wrong direction. The hook ends should not be against the tire sidewall. Whistlepig knows this, BTW, as he posted that pic a year ago and someone made note of it then. The error was acknowledged and corrected back then.
   / How tight are your chains? #72
Yeah I noticed that, probably not a huge deal but I would put them out too.
Maybe a little harder to hook them the right way unless you had the install tool.
JB
   / How tight are your chains? #73
JB
The binder tool hooks a full link (of the tensioner) and a link of the tire chain, then you close the tool (same as any binder tool). Installing the hook on the tire chain isn't difficult...as long as you give it adequate slack.
From personal experience, you're not going to manually (without the tool) stretch those tensioner springs too far. That's why I have the tool...now.
Tirechains.com sells these tools. They have a picture...I reckon you've been around enough tools to determine how it's used.
Well I took my tractor out for a bit today, just threw a bungee on each side just for now... Oh yeah I learned a valuable lesson also! So here I go, when I was coming back up the hill on my property today going very slow pulling a little log my left rear wheel stopped?? So I eased forward again and same thing....? I got off the tractor and looked and apparently the one or two zip ties came off the inside and the chain got caught on the axle and rear fender mount! Thank goodness I was going really slow or things could have been really bad. I did bend the little bracket into a "U" shape that you pull the chains tight with, got that straightened out and went to the next link down and pulled the chain way tighter. Moved back to the outside and moved down one link also and had one heck of a time getting that one re-latched.... Actually pulled a muscle in my elbow but I got it and that chain is tight now!!!! I have to do the other wheel now not looking forward to it... I am going to get some heavier zip ties and go nuts with them to pull down that extra chain... They were rubbing against the 3 point arms with log on back, I am hoping when I get everything done correctly they won't hit anymore... I guess I should have never taken it out without checking their work 1st! So shame on me... I also had to tighten a fitting on the right side of my FEL because it was leaking fluid, it was the only fitting that was loose on the short hose, kinda weird?? So that was my exciting 4 hours on the tractor today
   / How tight are your chains? #75
Personally, I would not use zip ties - way too easy to snap them. I use small D-rings, u-bolts, etc.
Ken
   / How tight are your chains? #76
How much extra chain do you have? You shouldn't have more than 4-6 links.
Duct tape works too to tie up extra chain and hold the latches locked.
JB
JB
I have that one so tight that you would never be able to get duct tape around them... I'm think some wire.... Not sure on the links probably at least 6...
   / How tight are your chains? #79
i used #12 thhn wire and have 2-3 separate loops on all spare chain. If all works out good this year with these settings, ill probibly cut off alot of the extra chain at the end of the season.
Has anyone ever used the screw in studs? Was thinking about adding some to the rear inbetween the chains and front wheels??
2019 CATERPILLAR  XQ60 GENERATOR (A58214)
2019 CATERPILLAR...
*Selling at Royal Auction Tampa, FL Location* (A59231)
*Selling at Royal...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A59904)
2018 KENWORTH T680...
2017 FORD F350 CREW CAB 4X4 PICKUP TRUCK (A56138)
2017 FORD F350...
John Deere 1790 Planter (A59814)
John Deere 1790...
