How to fix crushed Gas can
   / How to fix crushed Gas can #21
HMMM, I just purchased a pair of new 5 gallon diesel cans at Menards recently, didn't even notice if they had vents or not. About putting water in a gas can, well, I recently rinsed out the fuel tank on my Honda Foreman 450, even with the tank off and upside down there was still moisture in it I couldn't get rid of...solution is to add some gas line antifreeze to absorb the water. Every other gas can I have is the older type with a vent...gotta go look at the ones I just purchased...TOMORROW.
Nope, the cans I purchased have no vent, it has been about 7 years since I purchased a new can. I have a bunch of those older type squarish Chilton brand cans, the problem with them is after a while the spouts start leaking because they don't seal well.
   / How to fix crushed Gas can #23
I swear, I've spilled more fuel with these 'Gestapo' mandated safety cans, than I ever did in the last 50 years..........
I was just 'Venting'...........(Pun intended)
Red - Gasoline
Blue- Kerosene
Yellow- Diesel
Correct?
   / How to fix crushed Gas can #24
Aint that the truth. Anyone tried putting a valve stem in the can for a vent? (removing the valve) does the cap seal up adequately?
   / How to fix crushed Gas can #27
Yup..... if you use a metal valve stem...
I have rubber ones n my cans and they are fine.
The hole side has to be exact or a hair undersized and pop them in obviously the valve stem is removed and get better caps not the plastic ones.
tom
   / How to fix crushed Gas can #28
I came for the info. I stayed for the entertainment.
Couldn't have said it better.:thumbsup::thumbsup::thumbsup:
   / How to fix crushed Gas can #29
Hmm...gives me an idea!:thumbsup: One question though: will the gas jockey fill my can if it has been "tampered with"?:(
   / How to fix crushed Gas can #30
What -- you won't fill your own can? -- I haven't seen a gas jockey in years!:eek::eek:
I bought some cans at an auction that looked just like the OP's picture -- and they were vented - a little gas in the hot sun and pop -- back to original shape
20 Ton Hydraulic Bottle Jack (A55787)
20 Ton Hydraulic...
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
AGT Mini SkidSteer (A50322)
AGT Mini SkidSteer...
Genie GTH 844 Telescopic Forklift (A53314)
Genie GTH 844...
2018 Kubota U17 (A53314)
2018 Kubota U17...
UNUSED Yellow Outdoor Patio Fabric Screen (A53117)
UNUSED Yellow...
