How to get a tractor unstuck
   / How to get a tractor unstuck #11
There is one good outcome from that method, and quite a few bad outcomes are possible.
Good luck whatever you do.
--->Paul
   / How to get a tractor unstuck #12
Well if ya do try it, please take video's.
   / How to get a tractor unstuck #13
Get a couple of bags of powdered lime and put about 1/2 bag around each tire. This will dry up the mud and you should be able to drive out. We use this method to get stuck concrete mixers out.
Bill
   / How to get a tractor unstuck #14
Lime works great in most mud.
We have laid a post across the back of rear tires,chained through the wheel,
Locked differential, put in reverse to turn wheels 1/4 turn which jacks the tractor up on top of the post. Then fill in the ruts with logs,or rocks,bricks then unchain post and drive out or get it to where another vehicle can pull easier.This is a last resort once we have gotten everything that can pull stuck also. It is a good way to raise the tractor off high center versus fighting a jack sinking in the mud.
2013 Ford Taurus Sedan (A59231)
2013 Ford Taurus...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2010 Toyota 7FDKU40 7,350lb. Straight Mast Diesel Forklift (A60460)
2010 Toyota...
2022 Transcend Xplor 245RL 30ft. T/A Travel Trailer (A59231)
2022 Transcend...
2018 RoGator 1100C (A56438)
2018 RoGator 1100C...
2013 Ford F-450 4x4 Crew Cab Little Beaver LS300 Drill Rig Truck (A59230)
2013 Ford F-450...
