Ritothebull
- Joined
- May 5, 2018
- Messages
- 367
- Location
- Brooksville, Florida
- Tractor
- Massey 461 Massey 165 . KTM SDGT
I have been welding with stick as my only method for many years. Not that I'm good at it or have done it a ton, but I can make metal stick together passably. It doesn't look great and I wouldn't stake my life on the results but most of my projects are non-critical and they hold up fine.
Stick welding is a pain though, probably because I'm not that good at it. Sometimes it is hard to strike an arc. Probably using the wrong type of rod. And I probably should get a better helmet that is auto-darkening so I can see what I'm doing before I strike the arc randomly an inch away from where I'm supposed to be starting. I know I have some challenges overall. Going to work on those. My welder is an ancient (30-40 year old) Lincoln buzzbox. I think it is in decent condition but I guess it is possible that it may not be in tip-top form itself so that may contribute to my pains. I have replaced the leads and ends recently.
But I'd like to get into MIG welding. It seems like it may be a little easier to control things and not be as futzy as stick welding. Is this a reasonable thought? Does anyone have a pointer for someone who knows the general concepts of welding to get up to speed on MIG? Things like choosing fluxed vs. non-flux wire, what gas is needed, wire thickness to choose, wire speed, etc? I'd like to learn about it before buying a new welder.
Thanks,
Rob
Sounds to me like you would probably be able to do most of your repairs with your old stick welder if you could use it properly, I would recommend you find someone to check it out for you and get a bit of instruction on using it before you consider getting a mig. Going to mig because stick is not working out so good is like getting a bigger boat because your not catching any fish in the small one.
