How wide a disk harrow for a 2660?
   / How wide a disk harrow for a 2660? #1
Haywire
Central Kentucky
Tractorless :(
Just a 4 footer to cover the tracks or can it pull a 5 foot disk?
Ian
   / How wide a disk harrow for a 2660? #2
I would think if you have light soil and don't set the disk too deep, it will pull it if you have R4 tires. My turfs don't do as well.
   / How wide a disk harrow for a 2660? #3
Could I talk you into a four foot tiller?
Sure... if you include the added cost... :) A tiller would be preferable except for doubling the price tag.
Ian
   / How wide a disk harrow for a 2660? #5
Haywire, is this patch you showed on the other thread the garden you're thinking about? Do you have anymore plots to work, or is this about it?
I'd probably be doing 2 others that size if I got the implements.. friends gardens.
   / How wide a disk harrow for a 2660? #7
With a tiller you at most might be two times across and you are done.
With a disc, while you will never get it to work as good as the tiller even on the tenth trip!!!!
   / How wide a disk harrow for a 2660? #8
Not true at all. I can do it just as well with a disc, and do it faster and cheaper.
   / How wide a disk harrow for a 2660? #9
Depends again on your soil. We have disks and with our hard clay soil, you might as well save your time unless you plow first. It takes a very heavy disk on our fields to get by without breaking the soil up.
If the ground is not tilled regularly, like in a field, all a 4-5-6 foot light to medium disk behind a compact tractor is going to do is scratch the ground up a bit unless you spend all day running around on it and you still won't get good penetration. We have to use a rotary tiller, plow or something.
All dirt is not the same.
   / How wide a disk harrow for a 2660? #10
I guess I was assuming we weren't talking about sod. Neither a disk nor a tiller is designed to break soil, though both will with enough time.
2005 TerraGator 8104 (A55302)
2005 TerraGator...
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2006 CATERPILLAR 320CL EXCAVATOR (A59823)
2006 CATERPILLAR...
T/A Flatbed Trailer (A59230)
T/A Flatbed...
2012 TOP HAT TRAILER GOOSENECK FLATBED TRAILER (A58214)
2012 TOP HAT...
