How wide a disk harrow for a 2660?
   / How wide a disk harrow for a 2660? #1
Haywire
Central Kentucky
Tractorless :(
Just a 4 footer to cover the tracks or can it pull a 5 foot disk?
Ian
   / How wide a disk harrow for a 2660? #2
I would think if you have light soil and don't set the disk too deep, it will pull it if you have R4 tires. My turfs don't do as well.
   / How wide a disk harrow for a 2660? #3
Could I talk you into a four foot tiller?
Sure... if you include the added cost... :) A tiller would be preferable except for doubling the price tag.
Ian
   / How wide a disk harrow for a 2660? #5
Haywire, is this patch you showed on the other thread the garden you're thinking about? Do you have anymore plots to work, or is this about it?
I'd probably be doing 2 others that size if I got the implements.. friends gardens.
   / How wide a disk harrow for a 2660? #7
With a tiller you at most might be two times across and you are done.
With a disc, while you will never get it to work as good as the tiller even on the tenth trip!!!!
   / How wide a disk harrow for a 2660? #8
Not true at all. I can do it just as well with a disc, and do it faster and cheaper.
   / How wide a disk harrow for a 2660? #9
Depends again on your soil. We have disks and with our hard clay soil, you might as well save your time unless you plow first. It takes a very heavy disk on our fields to get by without breaking the soil up.
If the ground is not tilled regularly, like in a field, all a 4-5-6 foot light to medium disk behind a compact tractor is going to do is scratch the ground up a bit unless you spend all day running around on it and you still won't get good penetration. We have to use a rotary tiller, plow or something.
All dirt is not the same.
   / How wide a disk harrow for a 2660? #10
I guess I was assuming we weren't talking about sod. Neither a disk nor a tiller is designed to break soil, though both will with enough time.
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A59905)
2018 INTERNATIONAL...
Great Dane Van Trailer 1989 (A56438)
Great Dane Van...
2016 ISUZU NPRXD 14' BOX TRUCK (A60430)
2016 ISUZU NPRXD...
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56438)
2023 Kubota...
SKIDDED FRAC TANK (A58214)
SKIDDED FRAC TANK...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
