How wide a disk harrow for a 2660?
   / How wide a disk harrow for a 2660? #11
The tiller would be a two pass system unlike the disc at a mere 100lbs per foot at maximum weight for a three point hitch. I certainly wouldn't even consider trying to convert sod to tilled soil with clay as a factor. You might have good luck in sandy soils but not anything heavier.
Todays farmers normal secondary tillage disc harrows run 300 to 400lbs per foot of cut and that is for secondary after a plow of some sorts!
   / How wide a disk harrow for a 2660? #12
I guess I was assuming we weren't talking about sod. Neither a disk nor a tiller is designed to break soil, though both will with enough time.
Agreed, sod is a bear to break up with either, but even in our ground a regular duty 3-point won't do it. The family that farms our land uses a heavy disk or chisel plow. When we were farming it with much smaller equipment, we had to use a mold board plow and then a disk with a harrow drag.
I probably assumed wrongly on the type of soil as that will surely make a difference.
Could I talk you into a four foot tiller?
Well, you didn't try very hard, but I think I talked myself into a tiller. After talking with a few other people about disks and seeing the price of disks with decent adjustments, I started an automatic monthly transfer to my savings account for the purpose of funding a tiller this fall.
I figure if I'm breaking new ground, I can tear it up with my middle buster and then till.
Ian
   / How wide a disk harrow for a 2660? #14
Well, you didn't try very hard, but I think I talked myself into a tiller. l.
Ian
Thats the better way to do it!!!!
It appears that my middle buster won't be much good in anything but decent topsoil... two passes pushed the 4" of topsoil out of the way and just scratched the clay underneath.
I think I'll put a 12" bottom plow on my 2 year implement list.
Ian
attachment.php
   / How wide a disk harrow for a 2660? #16
I've went to Barlows at least twice to buy a disc. Steve keeps asking me why I want it and twice he has told me it won't be very good for what I want to do with it so he has talked me out of buying it from him twice. I now have a single bottom plow that I bought/traded Milkman out of and I may try using it this year to see what it will do and then use my tiller.
   / How wide a disk harrow for a 2660? #17
Ian
No need to use the middle buster first get a king kutter 4' tiller from tractor supply like I did and in 2 or 3 passes you can turn never broken sod into ready to plant garden.
   / How wide a disk harrow for a 2660? #18
I don't believe a lightweight middle buster or moldboard plow will work well in that hard clay, I know it won't in mine. We do use a moldboard plow, but it is a heavy three bottom, with the BX, we use a tiller. Even with the tiller, it takes a while to chew down into it. Last year, I ran my L5030 with bb and scarifies down before tilling to break it up.
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
43023 (A59228)
43023 (A59228)
(INOP) JLG E300AJP ARTICLATED MANLIFT (A60429)
(INOP) JLG E300AJP...
2020 CATERPILLAR 299D3 XE SKID STEER (A60429)
2020 CATERPILLAR...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
