Hydro's and brake pedals
/ Hydro's and brake pedals #281
Skidsteer bucket. They are shaped different than "typical tractor" buckets though.
I've worked 60HP Bobcat and CAT SS and CTL. They are very capable of digging. My experience is only with 35hp and smaller utilities(Kubota L35) and CUT's. Similar sized skidsteers and compact track loaders will easily outdig a similar HP tractor. That is probably why the tractors have a lighter construction bucket. That is alos why they call it a loader, not a digger.
I have bent the top/back of the bucket on my little CUT. More dinged it up. In my case, a heavier duty bucket would really limit loader, since it only lifts 650lbs with bucket it has.
The buckets on my buddies 56hp Bobcat SS is built like a tank.
My tractor dealer suggested I consider the HD bucket instead of the standard. (Kubota Grand L-4610HSTC) I considered it a good idea and abuse the heck out of the FEL and bucket. I have done considerable excavation with it. My bucket has a HD pipe across it at the top and a HD cutting edge welded on and reinforcements at the sides of the bucket near the cutting action.
Pat
/ Hydro's and brake pedals #282
Heck Pat, I just use whatever I've got to the best of my limited ability!:laughing:
Save it for the suckers, I know the real deal!
Now back into the phone booth and change out of your tights!
Pat
/ Hydro's and brake pedals #283
.... OK, I confess, since the brakes and HST pedal are on the same side it is a bit awkward BUT I CAN DO IT!
Pat
BEEEEEEEEeeeeeeeeeeeeeeeeeeep___________________________
CLEAR!!!
CHUNK!!!
_______/\__/\__/\__
O.K. I'm back now.
/ Hydro's and brake pedals #285
Phone Booth??? Where does one find them these days??:D
Tights, haven't worn them in ten years now but I think I could still find them!:D
Skiing and cycling they become quite comfortable when it gets colder.:thumbsup:
/ Hydro's and brake pedals #286
I am one of those on the, "Cuttin' brakes, We don't need no stinking cuttin' brakes!!!" side of the argument BUT... when back dragging with the FEL bucket you have reduced traction on the front tires (or the tires are totally in the air) and being able to steer a bit with the cutting brakes while backing could be a good thing. I don't typically do it but it could be quite useful. OK, I confess, since the brakes and HST pedal are on the same side it is a bit awkward BUT I CAN DO IT!
Pat
You stole my thunder but this is how I smooth out gravel or just about anything. I actually raise the front wheels off the ground so I can put the most force on the bucket's edge. Of course this means I can only steer with the split brakes.
/ Hydro's and brake pedals #287
Some people know how to use a good thing. Others have more talent at denying its universal value or belittling its function.
larry
/ Hydro's and brake pedals #288
I do the same thing, except my tractor is articulated, so I can still steer. :D
/ Hydro's and brake pedals #289
Just one reason why articulated loaders are the way to go, much easier to steer with the bucket down in either direction.
/ Hydro's and brake pedals #290
It's kinda like curling without the brooms.:laughing: That's exactly what I do all the time. . . without all the yelling.;)
/ Hydro's and brake pedals #291
Phone booths may be viewed in several museums. I recall in the early 80's a quonset hut (left over from WW II) that was used as a Mexican restaurant (Chuey's) which had its original built in all wood customer booths and matching phone booth. An interesting lunch spot near the San Diego waterfront as its customers ranged from shipyard welders with goggles around their necks to bankers in 3 piece suits.
Oh, and regarding the split brakes for controlling the tractor in reverse while front wheels are in the air... While I recognize that it will work and that I can do it (even with HST and brakes on same side), I don't do it. I seem to get the job done pretty good trusting to luck and once in a while moderating the bucket force to let the front tires get just a little traction. In practice, for me, (your mileage may differ) I don't find that I need to use the brakes to do the back dragging as well as it takes to satisfactorily complete the task. It is not out of being stubborn, it is a lack of need. If I should get into a situation where I actually need to use the split brakes, I have them and can use them.
Pat
/ Hydro's and brake pedals #292
I do this while going forward when clearing snow. Gets rid of the ice or wet snow compacted on the asphalt drive!:D
If I'm backdraging on dirt I don't lift the front wheels and with the ice that is sorta a waste of time.:D
Actually the scarcity of phone booths is of concern to me as I do not have a cell phone.
/ Hydro's and brake pedals #293
Do you still carry a dime? :laughing:
(Back when I was in Boy Scouts they always said you should carry a dime in case you had to make an emergency phone call. )
Now a days they tell you not to do anything stupid in public because everyone carries camera phones! :confused2:
/ Hydro's and brake pedals #294
I used to have a pair of Top Sider deck shoes in "Penny Loafer" style. I once carried dimes in them but graduated to quarters due to inflation. Then pay phones began to fade away and the quarters were mostly a statement on our inflationary times, not "being prepared."
Pat
/ Hydro's and brake pedals #296
I have a Deere 3320, 32 hp E-hydro. the wheel brakes are on the left and the hydro on the right. I have no idea if the brakes work or not. I have never touched them. I think I have used the parking brake a couple of times when hooking up to the 3 point and always when I haul the tractor.
The intention of individual brakes is to shorten the turning radius if a brake is applied while turning. I have used them a lot on large farm tractors but never had the need on my little one. They probably have their place in operation but not for what I use my tractor for.
Dan
I was the 3rd person to respond and have to take back what I said. Last Saturday we had a sunny day and I wanted to get the barn cleaned out. The ground was still frozen and had about 4" of slop on the top. The only way I could steer the tractor was with the brakes even in 4wd. I thought it worked pretty well having the hydro on the right and the brakes on the left.
Dan
/ Hydro's and brake pedals #297
I have already had occasion to give my opinion on these braking problems, but I will say this again :
IMHO breaks on the left side for the left foot are extremely dangerous, especially in this country where almost every car has a gear transmission with the clutch on the left and the brake on the right. It is bound to create accidents in an emergency.
Split brakes are a must if you mean to steer a tractor with heavy implements in a muddy environment (even with my Ag tires and 4WD).
/ Hydro's and brake pedals #298
I know you are referring to using brakes with right foot out of pure instinct, it's that way everywhere whether manual or auto. Going 80 MPH there could be an issue of instinctively applying brakes with right foot, but these things are going 5-15 MPH, reflexes need not be so fast and on top of that the human brain is intuitive enough to learn new routines when you sit on the machine it says ok there's a job for the right foot and a job for the left, in that environment it becomes a newly learned instinct.
One word of caution though, if you never use your brakes with your hydro tractor, like I didn't for most of the time when I first got mine, the first time that you need the brakes it will not be instinctive.
I had a scare when I tried changing ranges on a slope and hit neutral instead, starting rolling down hill pretty quickly, took me a long moment to analyse the situation and think to myself, oh yeah that's what those pedals are for down there next to my left foot.
No panic, no searching for a brake with right foot, but it was a wake up call.
So my advice to those who claim to never need their brakes, just practice using them once in a while so your brain will remember what to do should the need arise.
JB.
/ Hydro's and brake pedals #299
I have a Grand L 3130 and prefer the clutch on the left and brakes on the right. Why you ask, because I'm an old codger and all my life, the clutch was on the left and brakes were on the right. Fortunately I discovered the benefit of HST and no longer need brakes. That said, I did have one encounter on the snow where I needed the left 'toe' brake and simply used my left foot to press the left pedal. No brainer! Why all the fuss? If a 60 year old person can move his left foot over his right, why does it take 30 plus pages to to figure this out?:thumbsup:
/ Hydro's and brake pedals #300
Sorry about the double response, but just realized that operators without hydrostatic drive may not realize that the tractor slows/stops as you release pressure on the hydrostatic control pedal. On my Kubota the brake pedals are located immediately above the control pedal, but they are rarely needed. If the need should arise to have both forward movement and an expedited turn radius, the control pedal can be used in combination with one of the split pedals to accelerate the turn.
I was a big fan of split brakes until 4WD came along. Now I use it mostly when using the front bucket to smooth gravel while backing-up, or near an edge in slippery terrain conditions. Kind of like doing the hokey-pokey and shaking it all about:laughing:.
JC
When your life flashes before your eyes, make sure you have plenty to watch :thumbsup:
Schulte XH1500 Series 4 15ft Pull-Behind Batwing Rotary Brush Cutter Tractor Attachment (A59228)
Schulte XH1500...
Kuhn FC400RG (A60462)
Hyster 60 6,000lb Diesel Forklift (A59228)
Hyster 60 6,000lb...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
2015 Adams Tender Trailer (A61306)
2015 Adams Tender...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
