i need help drilling 1 inch holes
   / i need help drilling 1 inch holes #31
oh god someone mentioned those drill doc things, in MY opinion those are not worth the cash at all. sharpening is not that hard, observing an OLD mechanical sharpener is all it took for me to under stand how to sharpen one off hand. movement has NO as in 0 twisting or rotation of the drill bit. the bit is sharpened by placing the cutting face flat in postion with the rotating grinding wheel. holding the bit in left hand and the right hand both, so that right hand is on the chucks end and the left hand holds the twist bits slightly away form the cutting end. the left hand stays put the right hand moves, the movement of the hand holding the chuck end of the bit is down at an angle twards the floor and the center of the base the grinder is mounted on. movement slows slightly as you go down, which cuts away more of the back side of the bit leaving the face sharp. the end contacting the wheel will actually move UP straight up the face of the wheel and will eventually come away form the wheel and the wheel removed material from the bit past the cutting surface.
anyhow like others said slow speed lots of lube.
mark M
   / i need help drilling 1 inch holes #32
Ok Daryl, you've convinced me that I need to add drill bit sharpening to my repertoire. As you said, the Drill Doctor doesn't quite cut it when a bit needs a lot of meat removed (i.e. when they're way out of whack). /forums/images/graemlins/smile.gif I've done a little bit of hand-sharpening, and can always (well, usually) get them better than they were, but I just can't seem to match the results obtained by the good doctor.
What grit/hardness/composition of wheel would you recommend? I think I have a J-60 aluminum oxide for my "fine" wheel, and about a 36-grit for my "coarse" on my (one and only) bench grinder. I do have a diamond-tipped dresser with a nice little shop-made jig for trueing them up.
Thanks,
J
   / i need help drilling 1 inch holes #33
re MikePA : <font color="blue"> </font>
I have no idea what this means but I promise not to send any links again.
Well guys,im cooking with gas now,well i was.I feel kind of stupid ,but my problem was with the el cheapo craftsman drill press.The recoil spring was screwed up so i thought the drill arbor was at the top,but that spring had jambed up things upso i was at the bottom of my travel when i got into my cut.Ihad to reef on it to get it back to the top.needless to say,its not part of my press anymore,its in the metal recycle pile /forums/images/graemlins/grin.gif
I found after i got going stepping up 1/8 wasnt working,for me,it kept fetching up,of course this is just a little 1/2 horse.It would also round over the outsides of my bits quicker,cause this was the only part cutting.By stepping upto 1/4 each time both problems were solved and i was drilling holes like a house a fire.I had to stop now and then to touch up my bits,speaking of which seem to be sharpenen up good [now i finally smartened up and brought a dish of water in to keep them cool during sharpening.I have learned the trick over the years of twisting and turning to give clearance on the back,in all i think im gonna be ok with the bit i got.I didnt have any cutting oil,i tryed a bunch of things...i will say you guys are right,wd-40 is usless for this.I found i was better off without it.
So i was drilling like a house a fire,when bang ...broke my drive belt /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gif /forums/images/graemlins/frown.gifI hope napa has one,tommorow,i can try sears but i doubt it,its a tiny thin v-belt,ill get some oil ,when im out.Thanks to all,your all great and have had good ideas,and im posting a pic in my thread twiddling my thumb ALAN
   / i need help drilling 1 inch holes #35
I know and respect the Rotobroach product. It's made by Hougen. Like a bleeding hole saw on steroids, what?
Since the entire hole is not turned into chips, the tool produces a slug, the HP and thrust requirements are way down vs a twist drill and the hole finish is very good.
Used with a mag base drill, also available from Hougen, this is a decent solution for those lacking adequate facilities. These tools are highly portable and are useable anywhere the mag base can be made to grip, like on ship decks or hulls and high up on multi story boilers.
They even make one for Aluminium.
Sadly, the average Joe isn't going to have access to these products.
All the best,
Martin
   / i need help drilling 1 inch holes #36
Martin, These drill are out of reach if purchased new, however EBAY has used ones frequently at affordable prices. I posted a couple of current links (and got hollered at) last night. I even use my B&D mag drill for post & beam morticing. Clamp a 1/2" plate to the beam for the magnet to grip on & push a 3 1/2" forsner bit with ease. It will make precision large holes with a boring bar.
   / i need help drilling 1 inch holes #37
Has anybody tried the Practool? It looks very fine on the PC, but I have bought some revolutioary items ovet the years, most of them are stowed away, together with some kitchen tools in the same category.
http://www.practool.com/
Gunnar
   / i need help drilling 1 inch holes #38
Good luck finding a belt.
For those that read 5030's comments on drilling holes. A drill point gage makes a difference with how well a hand sharpened drill will drill. I have an old Starrett drill point gage that is no long made. General Tool makes one that works good on straight shank drills. Click Here It is less than $10.
Starrett makes one that works good for just about any length. But as with any Starrett tool they are expensive. Click Here
Here is a older thread on drill sharpening. Click Here
When the art of hand sharping a drill is learned. /forums/images/graemlins/cool.gif The Drill Doctor is not a very good choice. /forums/images/graemlins/wink.gif
I noticed that the attachment in the other thread is not very good. I have a PDF file of the pages from a 1932 edition of American Machinists' Handbook that is 845 bytes. If you are interested please PM with a email address.
   / i need help drilling 1 inch holes #39
Yeah, using the steel plate is what I was alluding to with the "they even make one for Aluminium" claim.
My concern with acquiring tools like this from a private party on ebay is not knowing if it in fact is stolen property.
I'm just not comfortable with that.
All the best,
Martin
   / i need help drilling 1 inch holes #40
That tool looks like an absurdly expensive boring bar. Actually, buy a set of boring bars and cemented carbide tool bits and you have the same thing. Most drill presses will chuck up to a 1/2" boring bar, some 5/8".
www.use-enco.com They have a number of bars.
2019 Ford F150 XL (A57148)
2019 Ford F150 XL...
SCREENER (A58214)
SCREENER (A58214)
2007 Case IH 275 Tractor (A59814)
2007 Case IH 275...
Toro (A56857)
Toro (A56857)
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2016 Ford F-150...
2018 KOMATSU PC138USLC-11 EXCAVATOR (A60429)
2018 KOMATSU...
