I Want to Build The Ultimate Root rake/Grapple
   / I Want to Build The Ultimate Root rake/Grapple #1
MrJimi
Elite Member, Rest in Peace
NorthEast, Florida
Case 1845 C Skid steer
I am looking for the better features to incorporate in this. My machine is 75 inches wide, it will be that wide at the root rake part and I had in mind a 3 foot wide for the top grapple, I have gotten some real good ideas from J_J and its a good design, I would like a double joint for the top, kind like a bending finger, I have seen one and I did not save the picture or site.
thanks
Jim:)
   / I Want to Build The Ultimate Root rake/Grapple #2
Why so wide? I always thought 60" was more than enough for width. I could maybe see it if you were raking sand at a construction site to gather bricks and debris but other than that it is just added weight to decrease the FEL capacity. My 2 cents, YMMV but I'm open to suggestions. Oh yeah, the ultimate grapple should have a beer cooler as well.
Well, my Case 1845 C is 75 inches wide and as for the cooler part, only after I'm home and its unloaded. And we live in Florida and we don't have any real dirt here just sand :D
Jim:)
   / I Want to Build The Ultimate Root rake/Grapple #4
Well i own a bobcat t300 and have the root grapple made by bobcat on it. the freature i love the most is the dual indepandant top clamps. 2 is better than one because thry both can clamp independantly of one another which is essential when haulin trees and brush.
It is a great design and i strongly suggest you take a look at one and take notes i will send photo's if you want of mine
hope that helps
Evan
At first I wanted a wide bottom with a smaller top grapple but I've been looking a lot aand I like this design like this I will make something simular to it, what are your thoughts? I like the way it can be curled forward and back drag more brush, here is site and click on the first video and you will see what I mean
Jim:)
   / I Want to Build The Ultimate Root rake/Grapple #6
I agree with the earlier comment that there is little advantage but substantial penalty for using a grapple bigger than 60". I'd even go lower and say for almost any grapple task a 48" grapple will do fine. The comparison is not similar to bucket capacity where there is an advantage to bigger. You can grapple almost anything with a small grapple that you could get into a larger one. Trees, no advantage for large as they stick out the sides anyway. Brush tends to "stick" together so you can get huge amounts into a smaller grapple just by pushing it in.
I'd guess there is a 500lb weight difference between a 48" and 73" grapple which means 500lbs less payload for the bigger one.
Small is beautiful.
   / I Want to Build The Ultimate Root rake/Grapple #7
Jimi, You know what I don't like about the Skid Solutions GR model. It looks like the unsupported front tines will bend if I push it under say a 6" stump and it wedges between 2 tines and starts prying them apart. The design lends itself to brush and log work but I think it needs longer front supported tines for root/stump/trash rake work.
   / I Want to Build The Ultimate Root rake/Grapple #8
I wouldn't be surprised if that model is actually made by Anbo since it looks a lot like their's. Here's a quote from Anbo's web site:
"AR 400 and steel teeth that have over 4 times the strength of A-36 mild steel."
I think many manufacturers use mild steel instead of AR400 or T-1.
   / I Want to Build The Ultimate Root rake/Grapple #9
Let me add also that AR400 is $980 per 4x8x3/8 sheet. What a deal, 4 times the strenght at only 3 times the cost. Too bad it cant be used for structural steel, think of the tall buildings we could build.
   / I Want to Build The Ultimate Root rake/Grapple #10
I too was interested in the SkidSteerSolutions Root Grapple and I am just about to start to weld mine together. In fact, I based the design off the picture you posted. Mine is 60" wide and about 420 lbs. but could easily be scaled up or down. I had all of the pieces laser cut and I'm just waiting on the last pieces from the machine shop. I purchased the cylinders online and only have the hydraulic hoses and fittings left to buy. I figure I'll have about $1000 into it when I'm done.
I will try and post some pics but I have never done that before so I hope they work.
JCB 220XLC-4F EXCAVATOR (A60429)
JCB 220XLC-4F...
1983 INTERNATIONAL S SERIES WATER TRUCK (A57192)
1983 INTERNATIONAL...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
JCB 507-42 TELESCOPIC FORKLIFT (A60429)
JCB 507-42...
John Deere 5103 (A53317)
John Deere 5103...
2011 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2011 VOLVO A40F...
