Illegal to use #2 Heating Oil in Machinery in MA
   / Illegal to use #2 Heating Oil in Machinery in MA #41
How about you get a 12 volt power supply and be done with it correctly?
   / Illegal to use #2 Heating Oil in Machinery in MA #42
I'm kinda baffled by your question.
What exactly are you referring to as a 12 volt power supply?
I checked into :
12 volt batteries
Transformers
Battery packs
Battery chargers
Voltage reducers.
Is there some item I didn't include here? If so kindly tell me what it is and where I can get it.
Thanks much!
== L B ==
I'm kinda baffeled by your question .
   / Illegal to use #2 Heating Oil in Machinery in MA #43
LBROWN yes that was what I wanted to do find a cheap transformer that would work.
The battery seems to be the best for me and I have a small float charger on it to keep it up.
I suspect a transformer that would have the right amperage and duty cycle will cost more that the charger route.
Al
   / Illegal to use #2 Heating Oil in Machinery in MA #44
I checked into :
12 volt batteries
Transformers
Battery packs
Battery chargers
Voltage reducers.
Thanks much!
== L B ==
like this
it plugs in 110 and gives you 12 volts
   / Illegal to use #2 Heating Oil in Machinery in MA #45
Essentially he HAS a 12 V power supply. It just comes in batter charger form, so it may put out 14V or so...
You plug it into a 110V AC outlet, it goes to a transformer, which puts out 12V AC (or thereabouts). The it goes through a rectifier circuit to change the AC into DC (or a reasonable approximation thereof). Then it goes to jaws for clamping onto battery terminals instead of some other kind of connector for, say hooking up to motor terminals.
Nice thing about an actual power supply is more control over voltage level and amperage, better power conditioning and rectification, depending on how fancy you get. Google 12Vdc power supplies and poke around some. But the battery charger is in essence the same thing, albeit with slightly higher voltage to overcome the battery's voltage level.
   / Illegal to use #2 Heating Oil in Machinery in MA #46
I think Radio Shack had something like this but I couldn't see paying $89 dollars for it to use on a pump that only cost me $69.
Besides i already had the battery charger.
Thanks for the photo and info.
How much does this one cost and where do I get one?
== L B == >>
MrJimi said:
like this
   / Illegal to use #2 Heating Oil in Machinery in MA #47
Iowachild said:
Diesel fuel way, way out sells home heating oil
How can the same fuel out sell itself?
Now if the statement read more fuel is used by on road and of road vehicles than is used for heating homes the statement would make sense.
   / Illegal to use #2 Heating Oil in Machinery in MA #48
Because it is NOT the same stuff here!!!!!!!!!!!!!!!!!:mad:
   / Illegal to use #2 Heating Oil in Machinery in MA #49
Luremaker said:
A friend of mine uses $5000/month of off road diesel to run his dozers and other equipment and he is not even a large contractor. Someone here also stated that one farmer was using $1200 of diesel everyday during the harvest season. *
I would guess that there is a lot of off road diesel being consumed every day.
*Way to much used to be concerend about the freshness of it.
   / Illegal to use #2 Heating Oil in Machinery in MA #50
I live in NW penna, I was buying off road diesel for my tractor and decided to try #2 heating oil. They sent me to the same pump, same thing just no tax.
Year: 2016 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A56859)
Year: 2016 Make...
Mahindra 4550-4L Tractor with Front Loader - 49 HP, 4WD, Heavy-Duty Utility (A56435)
Mahindra 4550-4L...
(4) FORD 255/65-17 TIRES W/ 6 LUG RIMS (A58374)
(4) FORD 255/65-17...
CASE INTERNATIONAL 4R DANISH TINE CULTIVATOR (A52708)
CASE INTERNATIONAL...
2014 Ram 2500 Pickup Truck (A55973)
2014 Ram 2500...
JOHN DEERE 2155 TRACTOR (A52708)
JOHN DEERE 2155...
