LBrown59
Super Star Member
- Joined
- Oct 27, 2004
- Messages
- 16,831
- Tractor
- 2003 Kubota BX1500/2004 Kubota Bx23/2005 Kubota BX1500
I already have the same tractor as the BX2350 in my BX23.Rlbol said:So on to the next question. other then the price why would you buy a certain bx model? such as bx 1850 versus 2350 etc...
maybe the better question would be is there a reason to buy one versus the other?
Will one do something the other will not?
I also have A CC GT 2554 that's smaller than the BX23 to mow on some slopes I won't get on with the larger BX23.
Since it's smaller than the BX23 I also use it to mow in the smaller tighter areas that I can't get the BX23 into.
I'm wanting to replace the CC with a tractor that is about the same size as it is and has the following features.
Diesel Engine.
4 wheel drive
Locking differential
Hydraulic lift for the front blade
Hydraulic lift for the rear tiller
Hydraulic mower lift
Power Steering
Rear and mid Power Take offs
Rear 3 point hitch
Rops
Since the BX1500 or BX1830 is closer to the size of the CC than it is to the BX 23 I chose the BX1500.
Or to put it another way the BX1500 is closer to the size of the CC than the BX23 or 2350 is.
The question is not is one BX model better or worse than another.
The Question is which one best suits the task you have in mind for it.
My choice was based on size needed and the intended purpose of the machine not upon which which BX model was better or worse than another.
